Mystery Valve On Hot Water Heater - NOT TPR - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2016, 07:48 PM   #1
Rewards Points: 6
I have a 1/2" od PVC outside my home with a steady drip of water. It is a few inches above the line that runs to the TPR valve on the water heater (confirmed by opening the valve). It's not the AC condenser line either. There are two more for them and I checked both units in the attic to confirm there was no water coming from the lines.
Top of water heater - i.stack.imgur.com/Igxp9.jpg
Looking at the top of my water heater, I'm baffled on what the set up is. I'm guessing one or both of the mystery 1/2" lines running off the hot and cold lines are the source of the drip in the 1/2" line outside since it's next to the TPR line and right on the other side of the wall from it.
As a guess, I figure they are there to relieve pressure instead of having an expansion tank? The pressure coming out of the tank drain is @ 50 PSI. When I cut off both the gate valves on the cold water line, the drip is still there so that leaves me thinking it's the hot water line.
Unknown valve - i.stack.imgur.com/Hn2i1.jpg
I believe the culprit is this valve coming off of the hot water line. I don't exactly what it is or why it is there. It's sprayed over with paint but it is a metal valve of some sort. It reminds me of a needle value for a hydraulic line which might make sense if it's some other mechanism to relive pressure but I think it's more likely a ball or gate valve I'm not familiar with.
Anyone know what this valve is and what it's purpose is? I'd love a larger explanation of why the 1/2" line on the cold water exists as well but my main priority is to determine what the one on the hot water line is and replace it to see if that stops the drip.
raggedballs is offline   Reply With Quote
Old 03-25-2016, 08:13 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,796
Re: Mystery Valve On Hot Water Heater - NOT TPR
I'm no plumber but it looks like it could be a TPR valve on the hot system. I've never seen such a thing but perhaps your jurisdiction did/does require one. The branch on the cold circuit might a system drain. You mentioned attic a/c which tells me you may have no basement and perhaps no floor drain in whatever room the HWH is in. Perhaps these branch were installed as a way to drain your lines to the outside.
lenaitch is online now   Reply With Quote
Old 03-25-2016, 08:22 PM   #3
Rewards Points: 6
Ya know, I ruled that out because the tank obviously has a TPR on it already but it might just be a PRV. If it wasn't painted over, it would look like what Google is showing for a poppet style relief valve. Thanks for that input!
Old 03-25-2016, 08:24 PM   #4
Rewards Points: 3,230
Welcome to the forum raggedballs, posted the pics for you. Somebody will be along to give you more advice, suggestions.
jmon is online now   Reply With Quote
Old 03-25-2016, 08:38 PM   #5
I agree, being how there is no expasion tank, that sounds about right. I see an arrow on bottom but everything else is painted over. Maybe some sort of tempering device???. Idk. As you stated, the TPR valve is the one coming out of the wh.
The plumbers will be along soon for more advice/suggestions.
Old 03-25-2016, 08:46 PM   #6
Rewards Points: 5,664
The cap appears to be knurled which is usually an indication it is to be turned with the fingers. If so, that would possibly indicate it may be pressure adjustable but is leaking.
Old 03-25-2016, 09:01 PM   #7
Rewards Points: 106
its a relief valve, once you may have had a coil in the boiler for hot water, you could just cap that as long as the water heater has its proper tpv..that pvc on the hot water heater tpv is a BIG code violation!!!
goobertime is offline   Reply With Quote
The Following User Says Thank You to goobertime For This Useful Post:
raggedballs (03-25-2016)
Old 03-25-2016, 09:03 PM   #8
Rewards Points: 6
Thanks for all the quick input here. Based on the feedback here and a bit of Google -
I believe this the mystery valve if it wasn't covered in paint -
http://www.homedepot.com/p/Watts-1-2...B&gclsrc=aw.ds
Reading the instruction manual for that piece, it seems to be added to relieve pressure before the TPR valve - http://s3.supplyhouse.com/product_fi...35-install.pdf
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Mystery valve on water heater? corey3589 Plumbing 13 01-19-2013 07:22 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
