Mystery Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2019, 11:05 AM   #1
Rewards Points: 2
Mystery toilet
My daughter has an older home with mixed materials for pipes and a toilet that doesn't completely empty when it is flushed. Eventually everything disappears and the toilet never backs up. So far the vent and clean out have been checked and there are no blockages. Does any one have a similar experience?
tohlson is offline   Reply With Quote
Old 09-10-2019, 12:44 PM   #2
Rewards Points: 6,550
Re: Mystery toilet
Had one that worked intermittently between poor abd very poor, but it worked. Finally I wen at it with the plunger and special snake and somewhere inbetween plunging and snaking I saw the handle of a tooth brush just barely visible. Cringing I quickly reached in and grabbed it before it decided to hide again.
Problems solved but there are other items that can get trapped in that toilet elbow and just reduce the flushing process.
Just a thought.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 09-10-2019, 12:52 PM   #3
JUSTA MEMBER
Rewards Points: 4,546
Re: Mystery toilet
Had a rental with similar symptoms.
Ran the toilet augur ( snake), in it got a RAT- TAILED comb out of it.
Flowed fine afterward.
ED
de-nagorg is online now   Reply With Quote
Old 09-10-2019, 02:54 PM   #4
Rewards Points: 746
Re: Mystery toilet
For now, advise users to hold handle down (by hand) just a bit longer than it would ordinarily. Should allow a better flush.
diyorpay is offline   Reply With Quote
Old 09-11-2019, 02:34 PM   #5
Rewards Points: 723
Re: Mystery toilet
The jets that allow water in the bowl can get clogged over time. That limits the water into the bowl which takes longer to flush. Dump a couple gallons in the bowl and see if it goes down faster.
ct18 is offline   Reply With Quote
