Mystery Damp Spot In Carpet Above Crawl Space - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By joed
  • 2 Post By allthemarbles
  • 1 Post By ZTMAN
  • 1 Post By allthemarbles
Old 11-02-2017, 09:30 AM   #1
Rewards Points: 18
Mystery damp spot in carpet above crawl space
We just bought this 1986 house and this morning noticed a fairly damp 3x4 inch spot in the carpet in the living room, which is above a wood frame foundation with crawl space below.
It was not dog pee and it smelled neutral. There is no ceiling drip.
I've gone through probably 12 paper towels on the spot but it's still damp (not soaking, but damp enough to keep making paper towels damp).
I noted the location then went into the crawl space under the damp area. It was near some heating ducts but there is no water evidence in the wood in the crawl space, except maybe a 2-3 feet away near a water softener (see photo) but this looks like old water damage. I see no pipes in the vicinity that are dropping down from that area. The water softener pipes are under the wood and visible. There is no visible dripping on crawl space floor.
There is a washer about 20 feet away in the added-on area.
I'm wondering is it possible the previous owner ran the washer drain pipe ABOVE the wooden floor frame but UNDER the carpet? My thinking is if that old damage is nearby, there must be a pipe above that wood that leaked at some point.
If I have to call somebody out, they'll need to cut at least three feet across into our carpet to lift it to where the dampness is at.
Thoughts?
allthemarbles is offline   Reply With Quote
Old 11-02-2017, 09:46 AM   #2
Rewards Points: 18,990
Re: Mystery damp spot in carpet above crawl space
Look up on the roof in that area to see if there's a sewer vent in that area, if so get up there and see if the rubber boot to seal it is shot.
If so it's a simple less then $10.00 fix.
Old 11-02-2017, 09:54 AM   #3
Rewards Points: 18
There is a sewer vent on the roof but it's about 15' from that area, so it could not possibly leak down to there, right?
The seal is shot, but I have a bag over it currently. Still, that's 15' away from this damp spot.
Old 11-02-2017, 10:19 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 32,020
Water can't flow up hill. So unless there is a pipe below spraying under pressure the water has to come from above.
Dave Sal likes this.
Old 11-02-2017, 10:36 AM   #5
Rewards Points: 18
So maybe there are pipes down there connected to the roof vent, but the roof vent leaks are dripping downhill to that spot? Just so odd that it's soaking upward into the carpet.
Regardless, I plan on buying a boot kit for the vent. It started snowing two days ago so perhaps that is related.
Old 11-21-2017, 10:57 AM   #6
Rewards Points: 18
As part of my personal improvement program of accepting my faults with grace, I confess I believe this post was entirely based on some snow my dog dragged in and caused to melt into the carpet.
Dave Sal and ChuckF. like this.
Old 11-21-2017, 11:26 AM   #7
ZTMAN's Avatar
Rewards Points: 628
Must have been a heck of a lot of snow for the subfloor to be stained as depicted. Tell your dog to wipe his feet before he comes in.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 11-21-2017, 11:34 AM   #8
Rewards Points: 18
I should have clarified this is my theory. Those stains are old but present, so this could very well happen again when it's not snowing and then I can salvage some of my pride.
profdlp likes this.
Old 11-21-2017, 05:08 PM   #9
profdlp's Avatar
Rewards Points: 54
Please don't tell us you live in the Bahamas. That would blow it.
profdlp is offline   Reply With Quote
Crawl Space Advice Perry401 General DIY Discussions 6 02-22-2014 02:23 PM
Flooring cold over crawl space cere19 Insulation 2 11-14-2013 11:38 PM
Crawl space .. add a duct? beachfront71 HVAC 2 02-20-2013 05:53 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-11-2012 11:53 PM
Air Barrier in crawl space biglurr54 Insulation 6 01-15-2012 08:50 AM
