Mysterious Leak From Toilet Base - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By hkstroud
  • 1 Post By Bud9051
  • 1 Post By TheEplumber
  • 1 Post By Wazatron
Old 06-06-2019, 03:51 PM   #1
Rewards Points: 20
Question
Mysterious leak from toilet base
Hopefully this is appropriate for the forum! I certainly think so, but anyhow. I have a leak around the base of a toilet. It seem pretty cut and dried that it must be a bad seal from under the base. So I just took up the toilet, after running to the hardware store and getting a new wax/seal, but it just looks very odd to me.
There is still a clear, and wet, ring of water around the outline of the base of the toilet, but there is NO indication of wetness, leaks, or "runs" of water from the existing wax seal at all. It seems pretty solid.
I figured maybe the toilet was cracked somewhere, though via a quick ocular pat-down I see no obvious cracks or leaks. I'll need to find a better spot to copmletely lay the toilet on its side to really inspect it.
So before I just put it back together and return the new seal OR move forward with just replacing the seal only to find out something is still leaking I thought I'd check with the forum to see if maybe this is sounds familiar, if I'm missing something obvious, etc. Thanks much!
Mysterious leak from toilet base-20190604_101911.jpg   Mysterious leak from toilet base-20190604_101920.jpg   Mysterious leak from toilet base-20190606_133328.jpg
Wazatron is offline   Reply With Quote
Old 06-06-2019, 04:07 PM   #2
Rewards Points: 20
Re: Mysterious leak from toilet base
I thought I'd share a couple shots of the under-toilet. Nothing jumps out at me.
Mysterious leak from toilet base-20190606_140427.jpg   Mysterious leak from toilet base-20190606_140438.jpg
Old 06-06-2019, 04:10 PM   #3
retired framer
Rewards Points: 17,434
Are you sure it wasn't just a leak at the water feed from the angle stop to the toilet.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-06-2019, 04:15 PM   #4
RRH
Rewards Points: 1,538
After you put it back and working. Then put food coloring or the toilet tank dye pills in the tank. After an hour and dont see anything.
Then flush the toilet and see if you see anything
RRH is online now   Reply With Quote
Old 06-06-2019, 04:17 PM   #5
hkstroud's Avatar
Rewards Points: 6,694
I agree that leak does not appear to coming from the wax seal. Reinstall toilet. Lay paper towels on the floor underneath the stop valve and the supply tubing to the fill valve. Lay paper towels under the tank to bowl bolts.
Is this by some chance a power flush toilet.
Take notice of when wetness appears.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 06-06-2019, 04:19 PM   #6
Rewards Points: 20
I can't say for certain now. I did check it; nothing was obvious and the porcelain around the area was dry. The leak seemed to start and first pool up at the front of the toilet base as well, furthest away from the input valve. But I suppose that could have just been the shape of the blow leading the leak forward somehow.
Old 06-06-2019, 04:21 PM   #7
Rewards Points: 20
I replied too quick! Thanks everyone for the suggestions and advice I really appreciate it. I will move forward with re-installing the tank as-is, spot-checking with well placed paper towels, and using food coloring to help pinpoint leaks as well.
Really happy I found this forum, everyone has been so quick and happy to help. I really appreciate it. Hopefully I can pay it forward eventually.
Old 06-06-2019, 04:24 PM   #8
retired framer
Is this a one piece toilet or a separate tank with a big rubber seal and two bolts to consider?
figure 7-14
Old 06-06-2019, 04:36 PM   #9
hkstroud's Avatar
Water appear to have run around the exterior of base of the bowl from the left side (where the stop and fill valves are) and pooled in the front of the toilet.
Nealtw likes this.
Harold,
Old 06-06-2019, 05:00 PM   #10
Rewards Points: 3,294
Quick story somewhat similar and you don't need to confirm.
Had built a small apartment in half the garage for my dad years back. Had his own bathroom and complained about the toilet leaking, same area. I knew the seal was brand new so applied a bead of silicone around the base. Nnext day same complaint but this time the source was obvious, the water was yellow. He was sitting down and not pointing down and urinating between the rim and the seat. Problem solved, he learned to aim.
Not entirely his fault as it was intentionally a small bathroom and a shorter bowl than he had been used to.
Bud
Nealtw likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 06-06-2019, 06:20 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 984
Leak between the tank and bowl caused by rusted out bolts?
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-06-2019, 06:42 PM   #12
Property Mgt/Maint
Rewards Points: 8,210
Replace the wax seal with one of these rubber seals. IMHO much better than wax, but if nothing else it's reusable so if you need to lift the toilet a few more times, no scraping and cleaning of the wax. https://www.lowes.com/pd/korky-rubbe...FcW3wAodnd0L-w
[political signature removed]
Yodaman is offline   Reply With Quote
Old 06-06-2019, 11:13 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 402
I was involved in an office remodel project. Part of the scope was to relocate an existing toilet to new bathroom.
The day after trim day, water was found at the base of the side wall adjacent to the toilet- just a little water too. That wall also had water lines supplying a mop sink on the other side. The GC thought either our toilet is bad or he shot a trim nail into the pipe.... As i investigated around the toilet, I leaned on the tank and water dribbled down from the tank to bowl bolts. Problem discovered- the washers were disintegrating. Quick run to Ace for a set of bolts and washers and leak fixed.
We now charge for toilet rebuilds when using used toilets....
Nealtw likes this.
Old 06-07-2019, 05:29 AM   #14
Naildriver
chandler48's Avatar
Rewards Points: 4,314
One more likelihood. We finished a basement remodel and I noticed a small amount of water at the base similar to yours. I always double seal my tanks so they are independent units, so there was no leak there, nor at the stop valve or hose connection. Total mystery. It only leaked when flushed. After laying down at the toilet for an hour or so, I noticed water running down the side. It was from a pin hole casting error from American Standard. Totally baffling.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-21-2019, 10:55 AM   #15
Rewards Points: 20
Hi all - quick update to end the thread. I did put everything back together and was exceedingly careful to check and double check all seals. So far so good. So I must have missed something in my initial spot checks. I hit that point where I was too worried about what might be going on where I couldn't see that I probably jumped ahead too far too fast. I appreciate all the insight and thoughts here!
jmon likes this.
The Following User Says Thank You to Wazatron For This Useful Post:
jmon (06-21-2019)
Tags
base , leak , toilet
