My Aqua PEX Re-plumb - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 3 Post By chandler48
  • 1 Post By TheEplumber
  • 1 Post By OverEngineer*48
Old 03-17-2018, 07:28 PM   #1
Member SE TX.
Rewards Points: 76
My Aqua PEX re-plumb
Well folks, I have finally got my hot water PEX pulled and the connections done in the attic. I going to do the first tie in at the far end of the run which is my shower and sink then start using it. I've done all of the expansions before that point. Question is, After I make that last expansion at the shower, how long of a wait period should I do before pressurizing the line? I know not to do it right away but not sure if I should wait 24 hrs or so. Also, If I have no leaks at my fittings can I be comfortable that they won't pop a leak anytime soon. Sorry for the paranoia but this is my first PEX project> Thanks for any help y'all can provide. Frank
OverEngineer*48 is offline   Reply With Quote
Old 03-17-2018, 07:42 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,532
Re: My Aqua PEX re-plumb
PEX is good to go after you release your compression tool. No need to "wait". What is an "expansion"? Where are you located? I question water lines in an attic in a cold climate.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-17-2018, 08:07 PM   #3
Plumber
TheEplumber's Avatar
I'd wait just a few minutes. But if that makes you uncomfortable, go longer
Did you check with Wirsbo website? I assume thats your brand.
OverEngineer*48 likes this.
Old 03-17-2018, 09:32 PM   #4
Member SE TX.
Rewards Points: 76
Did you check with Wirsbo website? I assume that's your brand.
Thanks The Eplumber. I downloaded Uponor's Pro install manual but it makes no reference to wait time. Our temps have been in the upper 70s and lower 80's so I'm assuming it shouldn't take long for the expansion to shrink onto the fitting tight enough. Won't need the hot water until in the evening so I hope a few hours is enough time. Once I get the farthest point tied in and the old copper abandoned, I will start prepping the other two bathrooms and kitchen. They will all go to a 4 port manifold in attic so I can tie them all in at one time. I guess I've got "Did I do this right?" fears since this is a first for me. Thanks for the info.
TheEplumber likes this.
Old 03-17-2018, 09:38 PM   #5
Member SE TX.
Rewards Points: 76
I'm installing the Uponor/Wirsbo Expansion PEX that requires PEX-A and special expansion fittings. It's a little pricier than the PEX-B that uses the crimp method but it is supposed to be the best of the two. It's been pressure tested to 1200 psi and freeze tested below zero for twenty hour with no failure. The tool for installing is a little pricey though if you want to use the cordless expander. With the manual expander you just about have to have three hands and I decided that wasn't going to work for this old man in tight attic spaces.
chandler48 likes this.
CHOOSE 1: deck post plumb; or flush post to beam russell.rp Building & Construction 7 10-11-2017 10:08 PM
Square and plumb a wall miamicuse Carpentry 9 01-15-2017 08:52 PM
Having difficulty getting plumb cut for shed roof rafters humberguy Building & Construction 11 05-11-2012 10:32 PM
Repairing Out of Plumb Non-Flat Walls Tom5151 Building & Construction 1 12-01-2009 12:48 PM
PreHung exterior door into a not plumb opening fark Remodeling 2 10-29-2009 05:46 PM
