Moving Washer And Dryer To Garage. Drain Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2015, 12:04 PM   #1
Rewards Points: 16
Moving washer and dryer to garage. Drain Help
Just bought a house and the W&D are currently in the kitchen. I would like to move them to the garage. I have opened up some drywall in the garage and there is water hookups, drain and gas line in the the garage already. It looks like the W&D was once there. In the picture you can see that the drainpipe has a coupling towards the bottom. Do I just need to add a wye and p-trap there for my drain?
Moving washer and dryer to garage. Drain Help-12244136_10207689159647742_1142717043_n.jpg
xcuter is offline   Reply With Quote
Old 11-12-2015, 01:15 PM   #2
Rewards Points: 767
Is that drain just picking up the washer now. I myself would cut in a tee with the trap going to a washer box and put a aav off the top with a louvered vent for access
ct18 is offline   Reply With Quote
Old 11-12-2015, 04:02 PM   #3
Retired Moderator
Rewards Points: 7,174
Is that 2" pipe? If so--Add a P-trap and riser to the pipe where the rubber coupling is-----and a washing machine box and I think you are set---the line appears to be vented ---
Old 11-12-2015, 04:32 PM   #4
Rewards Points: 16
something like this? and yes its 2" pipe
Old 11-12-2015, 05:28 PM   #5
Retired Moderator
Yes, exactly that---there is a 'washer box' that would be attached to the top of the pipe--and has hot and cold water feeds---much neater than a stand pipe.
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Moving washer and dryer? bassadict69 Plumbing 15 12-25-2011 01:47 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
Moving washer and dryer into Garage, perhaps some constucion needed? J187 Building & Construction 4 05-21-2008 11:53 AM
