Moving Toilet To New Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2018, 11:37 PM   #1
Moving toilet to new location
Hi everyone, I'm new to the forum. It looks like there is some great information on here! I am currently remodeling my bathroom and moving the toilet. The existing toilet flange is literally about 10" from the waste stack and vent. However, down at the bottom of the stack naturally is a cleanout at the end of a wye. The waste is currently cast iron. I have two questions I hope someone can help answer.
1) Can I cut the end of the cleanout off ( to make a straight pipe) add a two way wye with a new cleanout and tie the new toilet plumping to that? I just don't think there is enough distance to properly slope into the existing drain.
2) The new flange would have to drop 18" in about 4 feet, should I use 45's and wind down in somewhat of a coil to get it to properly slope?
I'm kind of scratching my head and any help would be appreciated. I need to get it done as I have a child in the way! Thanks!
Jdl3d is offline   Reply With Quote
Old 01-26-2018, 01:05 AM   #2
I guess I should have added a photo! You could see the clean out I would possibly tie i.nto
Old 01-26-2018, 02:20 AM   #3
retired framer
Rewards Points: 15,168
Re: Moving toilet to new location
Why not just move the flange you have?
Nealtw is offline   Reply With Quote
Old 01-27-2018, 10:23 AM   #4
Rewards Points: 777
How are you going to cut the end off. That looks like lead oakum to me.
ct18 is offline   Reply With Quote
A small insight in DIY tips to remove toilet flange. MichaelScorpion Flooring 3 12-27-2017 03:40 PM
toilet supply line location Rich Plumbing 4 05-28-2014 02:26 PM
moving a toilet over. plumberbear Plumbing 17 01-09-2011 09:51 PM
adding shower and moving toilet firehead67 Plumbing 1 08-15-2009 06:52 AM
moving toilet farrington135 Plumbing 5 11-19-2005 04:29 PM
