Moving A Toilet Drain To Another Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2018, 10:01 AM   #1
Rewards Points: 2
Moving a toilet drain to another floor
Hi everyone,
I have a half bath off of my kitchen that I would like to convert into a pantry and take the plumbing directly upstairs to convert a closet into a half bath. My question is in regards to the toilet drain. I don't want to have to cut the pipe in the crawl space and re-route it up through the wall. Is there any way I can just remove the toilet, slip a fitting of some sort into the drain and plumb it the rest of the way up? I don't care how ugly it looks since it will just be a pantry/storage closet. Attached is the drain pipe in question coming down vertically. Thanks!
njbfr is offline   Reply With Quote
Old 02-06-2018, 10:42 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,218
Re: Moving a toilet drain to another floor
Ayuh,.... My Guess is,.... The stack already goes to the roof,....
You'd need to locate it, 'n plumb in a "T" to the new toilet at the proper height,...
Bondo is online now   Reply With Quote
Old 02-06-2018, 11:38 AM   #3
Rewards Points: 88
You will not have the required vent pipe for the new toilet located upstairs.
Gregsoldtruck79 is offline   Reply With Quote
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Offset floor drain svaic00 Plumbing 19 03-05-2013 07:35 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 01:30 PM
Rear Discharge toilet on Floor mounted drain iramphal Plumbing 5 05-07-2011 09:56 AM
