Moving Sink Plumbing And Vent. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-29-2016, 08:28 PM   #1
Rewards Points: 14
Moving sink plumbing and vent.
I am trying to move a drain from front of counter to back and vent it. The counter will have no back and just open to living room so I didn't go straight up as I would have to take vent horizontal under counter and I have read a lot of places that is not to code. What I attempted is to route drain from concrete to wall and from there just do a normal sani tee. Come off that to trap, 3ft away. And go straight up through ceiling for a roof vent. Thoughts?
pomaikai is offline   Reply With Quote
Old 02-29-2016, 08:48 PM   #2
Rewards Points: 114
Depending on the plumbing code in your area, 90 deg fittings aren't allowed to be used in drainage (only in very few places) only venting. If i where you come up straight, install your drain, than a 2" cleanout, than install your vent. Bring the vent above the flood level rim ( above the highest point of the sink) than bring it over horizontal to the vent to tie it in.
Chrisathome is offline   Reply With Quote
Old 02-29-2016, 10:13 PM   #3
Rewards Points: 14
All of the 90s I used are from dwv and either a straight dwv 90 which is not as sharp a turn or a sweeping 90. I can bring the drain up to the bottom of the counter, but I don't have a good way to bring it up above the sink with our current design. I have a support column that I would have to loop around above the counter which would look bad, even if I boxed it in and made it decorative.
Old 02-29-2016, 10:19 PM   #4
Rewards Points: 14
Here is the 90 I used to connect to drain in floor and to turn up to vertical.
http://m.homedepot.com/p/2-in-PVC-DW...-100343360-_-N
The other ones I used to turn while horizontal are the sweeping elbows which has a larger radius then the above elbow.
Old 03-01-2016, 08:01 AM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
WTF is that mess??
WhatRnsdownhill is offline   Reply With Quote
Old 03-01-2016, 08:03 AM   #6
why dont you just turn the 90 at the back of the cabinet up, put a ty on it for the drain then a 90 ontop of the ty to go right for the vent, instead of that zig zag mess of piping?
Old 03-01-2016, 08:22 AM   #7
Rewards Points: 14
Just because that would not meet code because you can only take a vent horizontal 6" above the sink rim. This way seems to meet code even though other way would be my preferred route as well. I am tossed up which is why I am asking. Horizontal is allowed under special circumstances as long as you use standard drainage fittings for anything below 6" above sink rim. More of a case by case basis.
Old 03-01-2016, 08:27 AM   #8
Rewards Points: 14
I will do that, the plumbing is behind counter so if I need to switch it when I sell house I can without to much work. I will take it right below counter top and then go horizontal with drainage connections, not vent elbows.
Old 03-01-2016, 05:49 PM   #9
Rewards Points: 582
Originally Posted by WhatRnsdownhill View Post
WTF is that mess??
yep what he said ..:vs_no_n o_no:
Old 03-01-2016, 06:07 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 182
By strict code interpretation- you are correct. But, in this case run up under the counter top, then go horizontal to your vert. vent- slope the vent 1/4"/ft back to the sink (add a clean out under the sink)
What your proposing is how I rough in kit. sinks under windows all the time- never tagged for it
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (03-01-2016), WhatRnsdownhill (03-01-2016)
Old 03-01-2016, 09:04 PM   #11
LOL..your worried about code with that????? wouldnt pass in a second...as explained above, with a single fixture you can offset vent horizontally as long as any other fixture ties in above the flood rim..
Old 03-01-2016, 09:13 PM   #12
Rewards Points: 14
Thanks, I switched it over to go straight to back of cabinet, then straight up and take vent of to the side right under countertop. All horizontals keep a 1/4 per foot slope. I hadn't glued anything yet. I have only had a few things inspected for this remodel so wasn't sure how strict they were on plumbing code usually. They seem to be somewhat lax where here. Just don't do something obviously out of code
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
How to vent toilet, sink and shower on vent located on different wall? luvdairish Plumbing 11 05-12-2013 02:31 PM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Re-routing plumbing vent stack for sink around new larger window tpthaler Plumbing 4 04-07-2010 09:18 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
