Moving A Kitchen Drainpipe - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 02-14-2018, 07:29 AM   #1
Rewards Points: 960
Moving a kitchen drainpipe
I am renovating my kitchen which involves moving my kitchen sink. My condo board wants to know how I will be accessing the drain in the new location.
Below is my current setup and my new setup. Without opening the walls I can only guess how the drains and vents are setup.
Assuming theres sanitary tee at the existing kitchen sink location, can a 2 drain be wrapped around the wall as shown in the new layout picture? The drain will slope 1/2 per foot and be within 8 of the vent. Im fairly sure I have 3 1/2 metal studs behind the sheetrock.
Attachment 16188
jaketrades is online now   Reply With Quote
Old 02-14-2018, 07:38 AM   #2
retired framer
Rewards Points: 15,276
Re: Moving a kitchen drainpipe
Try the photo again.
The Following User Says Thank You to Nealtw For This Useful Post:
jaketrades (02-14-2018)
Old 02-14-2018, 07:40 AM   #3
Guapo
Rewards Points: 11,950
That's a fair question, from the board. Is there a cellar? Ask them for a plumbing plan.
Guap0_ is offline   Reply With Quote
Old 02-14-2018, 08:26 AM   #4
Rewards Points: 960
Old 02-14-2018, 08:28 AM   #5
Rewards Points: 960
There is a basement. Im on the 4th floor. There are no plans.
Im guessing the existing drain runs toward the toilet where the 4 drain pipe is.
Old 02-14-2018, 08:44 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 248
Do you know what plumbing code your town uses?
Given a multi story building, I would suspect a waste stack and vent stack at the existing sink location. They may be difficult to relocate. Since you don't have drawings it will be difficult to give the condo folks an answer without doing demo first.
jaketrades likes this.
Old 02-14-2018, 07:09 PM   #7
Guapo
Based on what you said so far, moving the toilet is a long shot especially if you can't access the pipes from the floor below.
Old 02-14-2018, 07:17 PM   #8
Rewards Points: 960
Yup pretty sure theres gonna be a santee at the existing sink location with a drain and vent line attached. Ive seen this setup in both bathrooms and my laundry room.
Im going to demo under the sink to find out.
Old 02-14-2018, 07:25 PM   #9
Guapo
I feel sorry for the 3rd floor neighbors.
Old 02-15-2018, 07:18 AM   #10
Peace be with you
DR P's Avatar
Rewards Points: 1,860
are the studs structural? because
2.5625" cut out of 3.5" is too much...
is there a window where sink currently is? because that
fact could make vent/drain stack to be further than 8' away
by any code your configuration distance between the vent &
horizontal drain is maxed out at 8' using 2" drain & 1.5" trap
meaning you might have to create a looped horizontal vent above
the flood rim of sink; the closer to the fixture the better IMO
but any windows in the layout could be an obstacle due to height
that said you appear closer to the bathroom plumbing than the
original sink location but I am not saying that would be an
economical nor easier option; just maybe more doable?
do you have the width to install a 3" space between current
wall and new cabinetry ? that would allow you to run the new
drain and water lines in front of wall and behind cabinets...
all that should be needed is a doubled 2x4 attached horizontal
& flat along the top of cabinet bases to secure those bases...
this will only work if you can reach the vent distance within code.
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
jaketrades (02-15-2018)
Old 02-15-2018, 08:16 PM   #11
Rewards Points: 960
DR P
Studs are not structural
No window.
Just redid that bathroom so no tie in option into the new bathroom.
What if I used a 2 trap? Does that buy me any more run?
I might be 9 away. Is that going to cause major issues?
Ill investigate the looped horizontal vent if Im not close enough to the existing vent.
Thanks for the insight!
Old 02-15-2018, 10:54 PM   #12
retired framer
At 1/4" per ft venting is lost at 8 ft, code would be less
jaketrades (02-16-2018)
Old 02-16-2018, 06:48 AM   #13
Rewards Points: 960
Its quite possible the 2 drain pipe under the sink connects to the 4 stack by my toilet. While replacing the subfloor on the bathroom shower, I saw a drain pipe coming from the general area of the kitchen. The distance from the existing sink drain to the toilet is ~14 feet which means the pipe will have to drop 3 1/2 which is quite possible given the 6 of space b/w the bottom of the joists and the ceiling below. Plus all the bathrooms in our buildings have dropped ceilings giving us roughly 3 of space for pipes in the bathrooms.
I am replacing my kitchen tile with wood flooring so I have the option to cut out a section of subfloor to look for the drainpipe and hope its within a reasonable reach from the kitchen floors boundaries.
I have ANOTHER idea that may or may not be easier (not sure its allowed either).
Install a santee at the new sink location and wrap both a 2 drain and 1 1/2 vent line around the walls to the existing santee. Is that allowed?
Old 02-17-2018, 03:59 AM   #14
Peace be with you
DR P's Avatar
Originally Posted by jaketrades View Post
DR P
No window.
1.5" trap ensures the 2" drain branch isn't overwhelmed/flooded
while maxed out to 8' before vented; so no a 2' trap would not help
& 9' total linear distance between trap & vent creates an S trap.
If you have a separate drain and vent stacks for kitchen,
the horizontal looped vent has to connect to the vent stack.
Peace
jaketrades (02-17-2018)
Old 02-17-2018, 02:13 PM   #15
Rewards Points: 1,932
If your dealing with a condo board I suggest you plan on hiring a licensed professional to do your plumbing.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Kitchen remodel - moving some feeds around for new appliances dman535 Electrical 5 09-15-2016 06:28 PM
Kitchen, Dining Room, Pantry mprice214 Electrical 23 07-14-2014 11:45 AM
Moving Kitchen Sink to Adjacent Wall farang Plumbing 8 09-12-2012 07:59 PM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 10:56 AM
