Moving A Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2016, 05:07 PM   #1
Rewards Points: 20
Moving a bathroom
I posted in the bathroom remodel area but no responses. Anyways I would like to move a bathroom. Since the new area will have new vents and connect to the sewer itself, what can I do to omit the old vents a d drain?
Can I cut everything and just cap it? I am moving the bath before I reroof so can i leave the vents up top and just cap them?
Will the old sewer be a problem if just capped and there's nothing running down for 20' where there used to be?
The house is slab on grade and built in 47 so I'm guessing cast iron for sewer then orangeburg in the backyard.
idontlikespam is offline   Reply With Quote
Old 08-12-2016, 05:11 PM   #2
Rewards Points: 144
Re: Moving a bathroom
I would not leave the old vents and cap them if putting on a new roof .Just something left for water intrusion and problems down the road.
mako1 is offline   Reply With Quote
Old 08-15-2016, 11:18 AM   #3
Rewards Points: 20
I suppose my post wasn't clear. When it comes to capping the vents that would only be temporary. Maybe for a month or two max. I'm pretty confident that'll work for me.
I'm more concerned about the drains and capping them below the slab. Does anyone have any advice?
Old 08-15-2016, 11:43 AM   #4
Rewards Points: 1,262
I would just cut the old drain about a foot from the slab and use the rubber cap with band clamp.
carpdad is offline   Reply With Quote
Old 08-15-2016, 11:47 AM   #5
Rewards Points: 20
Thanks. I guess that'll work for the sink. As for the toilet and shower can I put a rubber cap under ground?
Old 08-15-2016, 07:56 PM   #6
Rewards Points: 3,216
Shouldn't be any problem. Check with your local building code department for sure on use of fernco fittings underground. Some jurisdictions may or may not allow them.
Fernco website states that Fernco caps are rated for above ground and underground use.
Additionally, Fernco recommends the shielded type fitting if using them as couplings underground.
jmon is offline   Reply With Quote
Moving a bathroom sink lisastewart Kitchen & Bath Remodeling 1 01-18-2012 10:51 AM
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 02:17 PM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
