Move Bathroom Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2018, 08:08 AM   #1
Rewards Points: 18
Move bathroom sink drain
Need to move bathroom drain plumbing to accommodate a new vanity. Photo shows what I have now. I need to move the pipe coming out of the wall over about 3 inches. Can I just cut out the existing tee joint, put in a new one rotated 90 degrees to the left (using mission-type couplings?), and then add an elbow to bring it through the wall where I need it?
lawyer101 is offline   Reply With Quote
Old 03-23-2018, 08:50 AM   #2
Guapo
Rewards Points: 11,950
Re: Move bathroom sink drain
You might not have to do all that work.
http://thaipipetrade.com/en/products...roup=1-003-005
Guap0_ is offline   Reply With Quote
Old 03-23-2018, 08:56 AM   #3
Rewards Points: 18
Thanks. Unfortunately I can't have the pipe coming out of the wall where it currently is as it will interfere with the drawers of the new vanity. I need to somehow relocate the point where the pipe meets the wall 3 inches to the left.
Old 03-23-2018, 09:35 AM   #4
Guapo
Can you exchange the vanity for something w/ drawers on the other side? When I enlarged a bathroom for my father, I knew that I was going to have to choose a vanity to fit the plumbing. It's easier than fitting the plumbing to the vanity.
Old 03-23-2018, 09:50 AM   #5
Rewards Points: 18
No, I did a ton of research before buying this one. Drawers on the other side would be even worse. I'm moving from a 29" vanity with no drawers to a 31" with drawers. I looked at dozens of vanities but could not find any that worked with the existing plumbing.
Old 03-23-2018, 10:12 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,830
You're putting a vanity in covering that drywall....
I'd take out enough drywall to access that drain/vent and use a couple of 45 bends on each vertical of the drain/vent to jockey the entire sanT over 3". I think the offsets of two 45's would be about 3"... though I don't have any here to go measure.
And repair the drywall patch.... it's gonna be behind the vanity.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-23-2018, 10:48 AM   #7
Rewards Points: 18
Good idea, that makes sense and sounds like it would be easier than my first idea. Thanks!
Old 03-23-2018, 07:44 PM   #8
Rewards Points: 1,926
YES Key is mission or proflex band couplings.
Old 03-29-2018, 03:33 AM   #9
Rewards Points: 202
I think you might have to do all that work.
MasterPipe is offline   Reply With Quote
trouble sealing bathroom sink drain DIYSeeker Plumbing 3 06-19-2017 11:55 AM
Low Profile 90 degree bathroom sink drain with stopper cubangt Plumbing 0 03-14-2017 12:53 PM
Removing bathroom sink drain plug (glued abs p-trap) ? westbank Plumbing 11 09-06-2013 03:03 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
