Mosquitoes & Odor Coming From Back-Up Sump Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2016, 11:03 AM   #1
On the Road Less Traveled
The Jeep Driver's Avatar
Rewards Points: 127
Question
Mosquitoes & Odor coming from Back-Up Sump Pit
I have a tri-level home, and a secondary sump pit in the garage, under the staircase that takes you from the lowest level of the house out to the garage. The pit is seldom ever used, only on heavy rain. Stagnant enough that mosquitoes are into it, and it is starting to smell. Anything I can put in the pit to eliminate both? I am not going to use chlorine, as I've read that it is bad on the pump.
The Jeep Driver is offline   Reply With Quote
Old 03-16-2016, 11:35 AM   #2
Rewards Points: 127
Talking
Re: Mosquitoes & Odor coming from Back-Up Sump Pit
I changed my search parameters and found"Mosquito Dunk" so there's one problem solved....
Old 03-16-2016, 11:51 AM   #3
Rewards Points: 5,642
[QUOTE= I am not going to use chlorine, as I've read that it is bad on the pump.[/QUOTE]
You must have read that on the web so it must be true.
I bleach my water well and neither my pump or myself have died.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Bondo (04-05-2016)
Old 03-16-2016, 12:08 PM   #4
Rewards Points: 127
Wink
I did read it online... from other home improvement sites... "chlorine bleach in concentrations high enough to control mildew will be damaging to pump O-rings and seals over time" and "Bleach use over the long term may cause deterioration of plastic and rubber pump parts as well as corrosion of metal parts." What concentration of bleach are you using? If I can trust your answer, as it is also on the web...
EDIT: Some of the answers on the aforementioned sites also advised to use bleach. I was simply avoiding chlorine as I'm not wanting to damage my pump.
Old 03-16-2016, 12:55 PM   #5
All the information I have read is that 3 drops of bleach / liter will purify drinking water.
Consider emptying the pit, refilling with fresh water treated with a 1/4 cup of bleach then add a couple cups of mineral oil. Mosquitoes won't like the oil on top.
The Jeep Driver (04-05-2016)
Old 03-16-2016, 01:00 PM   #6
Retired Moderator
Rewards Points: 7,174
ordinary dish detergent will drown the mosquito larva.
I bleach one of my pits(when it gets to smelling bad)--then flush it out with clear water---then a shot of dish soap.
lenaitch (03-16-2016)
Old 03-16-2016, 01:12 PM   #7
Rewards Points: 459
Why not just cover the pit?
It's a good practice and now part of IRC code.
Nick DIY is offline   Reply With Quote
Old 03-16-2016, 04:22 PM   #8
Rewards Points: 1,862
I bleach my outside fountain constantly that little pump is 5 years old and runs 24 /7 all year.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (03-16-2016)
Old 03-17-2016, 06:02 AM   #9
SHEPLMBR's Avatar
Rewards Points: 178
yeah... most pits have lids that seal it..unless it's a pedestal pump
SHEPLMBR is offline   Reply With Quote
Old 04-05-2016, 11:31 AM   #10
Rewards Points: 127
...then add a couple cups of mineral oil. Mosquitoes won't like the oil on top.
I wonder if the mineral oil would also help with the odor issue, in the same fashion that
does. (I thought it was a spoof the first time I heard of it.)
The pit has to be open to collect flood water.
Thanks for all the responses!
Tags
mosquito , sump pit , sump pump
Sump Pump running constantly and spraying water back into pit CubsWin Plumbing 17 01-04-2017 09:25 PM
Back to back fixtures misterd0 Plumbing 24 03-01-2013 09:04 AM
Didn't have the 'green thing' back in our day gma2rjc Green Home Improvement 6 07-05-2012 05:23 AM
Sump Pump Basin install, existing rough sump hole. McSweny1103 Building & Construction 3 02-12-2012 02:45 PM
sump pit question curlyrip Plumbing 2 08-21-2011 06:36 AM
