Moisture?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2015, 08:49 PM   #1
Rewards Points: 1,192
Moisture??
Not sure what this is but it looks to be moisture coming through the tile. We has this bathroom installed about six months ago and had no leaks etc.? Yesterday was our first warm day of the year.... Could that have anything to do with it?
Mstrlucky74 is offline   Reply With Quote
Old 04-19-2015, 09:04 PM   #2
Retired Moderator
Rewards Points: 7,174
might be condensation---cold bowl and moist damp air---
Best to check---dry the area out with a hair dryer--then tuck some paper under the toilet(if space allows) and flush the thing several times---if the paper under the toilet is wet--replace the wax ring---
jmon (04-20-2015)
Old 04-20-2015, 05:33 AM   #3
Thanks a lot
Excessive moisture rediris Building & Construction 1 04-21-2012 09:43 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
