Moen Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2017, 12:01 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 240
Moen Shower Valve
I had my Moen shower valve replaced less than a year ago.
The plumber had set my temp setting a little too low.
A couple of weeks ago I adjusted the plastic settings to be a little hotter.
Now I am noticing the handle does not turn as "freely" as it should.
Especially towards the hotter side. It does not bind up yet, but want to fix it before it starts.
Did I go too tight on the center screw, or something else need adjustings
Any suggestions?
Barry
Barry J is offline   Reply With Quote
Old 01-16-2017, 02:13 PM   #2
Rewards Points: 3,418
Re: Moen Shower Valve
Sometimes taking out the cartridge and putting a little silicone plumbers grease on it then reinstall it helps. Sounds like the plumber just put it in without any lube. Nothing wrong with that, it's just that I like adding the grease moen sends you with a new cartridge.
You can call or go online and ask moen directly what to do. It's not leaking so they probably won't send you a new cartridge, but may recommend a silicon grease to use to help with the stiffness. Or they may send you a whole new cartridge with the grease for free. Very reputable company. They will need model number of faucet. Just a suggestion.
jmon is offline   Reply With Quote
Old 01-16-2017, 07:48 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,830
Just happen to have the number litterally in front of me...
1-800-289-6636
Moen is GREAT..... I have two old Moentrol shower valves that are rough operating/slight leak (really because we have very hard water).
Technically the valves are guaranteed for life only for the original owner... but MOEN is great.... they immediately sent out two new ones.
I think Moen will guarantee their stuff, as long as it is not some plumber or reseller or abused.
Plus their valves are GOOD.
Do have your valve model available or within sight... Moen just wants to make sure they get you the right part.
But... You probably don't have a problem apart from some plumbers grease... but they will help you right away.
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 01-17-2017, 12:22 AM   #4
Rewards Points: 134
I think you should call professionals, because a plumber is a tradesperson who specializes in installing and maintaining systems used for potable water, sewage and drainage in plumbing systems.
harrisong35 is offline   Reply With Quote
Old 01-17-2017, 08:43 AM   #5
hkstroud's Avatar
Rewards Points: 6,692
Take the handle off and adjust the stop again. You probably just didn't get it positioned quite properly. You can't screw the center screw to tightly.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 01-17-2017, 09:31 AM   #6
Rewards Points: 6,290
Maybe he isn't a slow learner. He been there, done that less than a year ago.
Leaky Shower gypsy57 Plumbing 17 08-24-2016 10:37 AM
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Moen Single Valve Shower Handle problem! F8James Plumbing 3 04-16-2011 04:32 AM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
