Moen Shower Seat Install - Does It Compromise Water Proofing - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By bob22
Old 10-31-2017, 12:08 AM   #1
Rewards Points: 960
Moen shower seat install - does it compromise water proofing
I am planning to place a foldable shower seat in my shower and it involves drilling screws into the tile. This means the water proof red-guarded cement board layer will be penetrated. Is that an issue?
I was planning on placing opposite the shower fixture. Bad idea?
jaketrades is offline   Reply With Quote
Old 10-31-2017, 01:06 AM   #2
retired framer
Rewards Points: 15,354
Re: Moen shower seat install - does it compromise water proofing
You should be able to put silicone behind the brackets to waterproof it but I would make sure I had real good blocking strong enough that it would take what ever abuse two people could come up with.
jaketrades likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
jaketrades (10-31-2017)
Old 10-31-2017, 11:24 AM   #3
Rewards Points: 960
2x4s. I see youíre thinking through all possible scenarios.
Tenants would lose part of their deposit if I had to fix that.
Old 10-31-2017, 01:39 PM   #4
Rewards Points: 2,636
They make free-standing shower seats/stools. Might be an option.
bob22 is offline   Reply With Quote
Old 10-31-2017, 02:08 PM   #5
Rewards Points: 960
Yep Iíve seen them. Donít look as sleek. Plus they occupy space. This seat folds up.
Old 10-31-2017, 02:21 PM   #6
retired framer
Have a look at what they do to hang a wall mount toilet. I think I would want a steel frame in the wall with bolts sticking out of the wall.
No water at moen shower valve mj12 Plumbing 4 06-10-2016 08:48 PM
Button broke on Shower Head that redirects water to Handheld Massager ace2013 Plumbing 2 01-19-2014 09:18 AM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
