Moen Shower Control Doesn't Have A Hard Stop To Turn Off Water - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By TheEplumber
  • 1 Post By dreiding
Old 06-17-2016, 04:48 PM   #1
Rewards Points: 40
Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water
I've recently purchased a used house with the main bathroom shower having a moen fixture that you have to point the knob up to turn the water off. Turn left for hot water, right for cold. Was this fixture installed correctly? This is the first time I ran into a fixture that doesn't have an easy stop position. My fear is my guest will break the knob trying to turn if off to the right or left. Here's a picture of the fixture.
Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water-image-3421105503.jpg
Thank you,
- Pat
dreiding is offline   Reply With Quote
Old 06-17-2016, 07:00 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water
You are missing a part--remove the handle --there should be a plastic stop collar under the handle--call Moen---they will send you one.
Take a picture of the valve for use--someone here will tell you the model of the valve.
Old 06-17-2016, 07:05 PM   #3
Rewards Points: 1,848
It should turn right to left cold to hot and not turn to the left to right at all.
Ghostmaker is online now   Reply With Quote
Old 06-17-2016, 07:56 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,714
Doesn't that version of Moen pull out for flow control and left/right for temperature?
lenaitch is offline   Reply With Quote
Old 06-17-2016, 08:22 PM   #5
Rewards Points: 40
Thanks for all your feedback. I've taken the knob off, separated the parts, removed the back plate and took pictures of everything.
I placed green tape to show the top of the picture. I did not removed the cartridge. Hopefully the picture is enough.
What parts am I missing? Is it the right cartridge?
Thanks for all your help. You are all wonderful. Will Moen really send me the right replacement/fix it parts?
Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water-image-1507856050.jpg
Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water-image-2621752772.jpg
Moen Shower Control Doesn't Have a Hard Stop to Turn Off Water-image-3957009545.jpg
Thanks,
- Pat
Old 06-17-2016, 09:08 PM   #6
http://www.moen.com/product-support/...lacement-parts
Looks like you missing the two plastic parts in the stop tube kit.
Link is to the parts breakdown.
What they do is control how hot the faucet can get. Once you get them set the faucet to 110F to 120 F with the temperature stops.
43 C to 49 C
Old 06-18-2016, 08:16 PM   #7
firehawkmph's Avatar
Rewards Points: 2,580
Not this one. Moen makes one called a posi-temp, and another called a moentrol. I get the names mixed up, but I believe this one is the positemp, they don't pull out, just turn counterclockwise for on. The other does pull out for on and off, turns for temp adjustment.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
lenaitch (06-18-2016)
Old 06-18-2016, 08:50 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 162
Mike Hawkins
The old Chateau model pulled out. The crystal handle was common with them. If the OP wanted to change- other handles and trim are available.
firehawkmph likes this.
Old 06-19-2016, 06:58 PM   #9
Rewards Points: 40
Here's the final report on this issue.
I emailed the pictures to Moen. I received a detailed reply back the next day.
Turns out my problem was that the Positemp cartridge upside down.
Once corrected and the metal sleeve installed the knob only turned 270 degrees (9:00 -->6:00).
The off position is at 6:00.
Thanks for all your help and suggestions.
- Pat
TheEplumber likes this.
The Following User Says Thank You to dreiding For This Useful Post:
bob22 (06-20-2016)
Dishwasher Install re: How to turn off hot water wguttrid Plumbing 9 03-26-2014 05:23 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Water Meter Out of Control cdeliopo Plumbing 16 01-08-2012 10:08 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
