Moen Diverter Valve Install - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Gunnut
  • 1 Post By Nealtw
Old 08-27-2017, 11:08 AM   #1
Rewards Points: 20
Moen Diverter valve install
In the middle of a master bath reno. Installing Moen fixtures including posi-temp valve and 3 position transfer valve (3372). Looked for videos to get an idea of what to do. Only one video and the guy wasn't all that clear. He installed a 1/2" setback on the transfer valve from the main valve. I test fit a straight piece and it seems to line up fine. Any idea why he would set the transfer valve 1/2" deeper into the wall than the valve?
The instructions that came with the valve don't explain much.
Gunnut is offline   Reply With Quote
Old 08-27-2017, 11:23 PM   #2
retired framer
Rewards Points: 17,538
Re: Moen Diverter valve install
If this is the video, he is looking at the tab sticking out that should be right behind the drywall so you have to adjust for that.
Old 08-28-2017, 06:56 AM   #3
Rewards Points: 20
That's the video. What do you mean by 'tab'? Using straight copper from the mixing valve puts the plaster round even with the stud. Allowing for 3/4" combination of durock/tile is the same as the mixing valve.
FWIW I've also emailed Moen asking the same question. They haven't responded as of yet.
JimA
Nealtw likes this.
Old 08-28-2017, 07:19 AM   #4
retired framer
By tab I meant the flat area with screw hole for the plastic spacer. That would be lined up with the studs or the back of the backer board. I can't find enough info for the 3 way.
Old 08-28-2017, 07:41 AM   #5
Rewards Points: 20
Thanks for clarifying that for me. In my situation, using no rearward offset like he used in the video, the tab lines up flush with the edge of the stud. So I guess I am good to go.
Now where did I put my torch?
JimA
Old 08-28-2017, 07:45 AM   #6
retired framer
JimA
I found this. at
http://www.moen.com/products/Moen/Mo...onnection/3372
Install inst and methods terrible
[March 25, 2016]
Be careful and don't expect much from Moen. Professional plumber installed this with a complete shower and diverter that ordered. But the diverter valve cannot be installed in line with the Moen temp control valve, but has to be further back. Instructions are poor at best on this and now I have a valve that extends much farther out than the water/temp control. One would think - since they are in line with each other that you would not have to install 90 degrees and everything else just to get this connected when installed directly above the shower's water/temp valve. Paid extra for MOEN, but get nothing but a issue. Tile and backerboard now have to be removed and re-installed, but only after buying another diverter.
Gunnut likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Gunnut (08-28-2017)
Old 08-28-2017, 10:09 AM   #7
Rewards Points: 20
Thanks for finding that review for me. Definitely going to offset it now after reading that review.
Good thing I haven't found my torch yet.
JimA
Old 08-28-2017, 10:18 AM   #8
retired framer
JimA
I have the same unit waiting for me to play with so I am really happy you asked about it.
Old 08-28-2017, 01:30 PM   #9
Rewards Points: 20
This is the reply I just received from Moen:
Dear Jim,
Thank you for your interest and support of Moen products. The instructions do recommend installing the valves 11/16" so you would need to use a connector. If you do install straight above each other the top handle may stick out farther from the wall.
Old 08-28-2017, 01:33 PM   #10
retired framer
Dear Jim,
I have always liked Moen over all others but that is dissapointing.
Shower diverter valve r0ckstarr Plumbing 11 11-01-2016 06:07 PM
How to install Watts N45BU M1 pressure reducing valve Ed G Plumbing 2 02-18-2013 09:25 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Shower diverter valve prob ProAmateur Plumbing 1 12-27-2010 09:28 AM
Moen shower valve in new construction getaclue Plumbing 2 04-07-2010 10:11 AM
