Moen Camerist Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2017, 06:48 PM   #1
Rewards Points: 47
moen Camerist kitchen faucet
Hi,
My single handle kitchen faucet keeps coming loose. I tighten the set screw repeatedly and within a week the handle is loose. I even ordered a new handle and it is loose within two days!!! Any idea what I need to check and tighten?
nbmech is offline   Reply With Quote
Old 11-12-2017, 08:40 PM   #2
Rewards Points: 3,454
Re: moen Camerist kitchen faucet
Originally Posted by nbmech View Post
Hi,
Sometimes the set screw or threads get stripped and cause the problem you are describing. Sometimes locktite or a newer set screw may help.
Are you sure its the handle and not the base?
Post a video or some pics so the plumbers can better help you out. Thank you.
jmon is offline   Reply With Quote
Old 11-13-2017, 09:10 AM   #3
Rewards Points: 18,974
If you do use Loctite use the blue not the red, it only takes a tiny dab.
Moen Bathroom Faucet Leaking Under Cabinets Moose916 Plumbing 3 12-10-2014 11:58 AM
Low Flow Hot Water at Kitchen Faucet JulieMor Plumbing 12 05-22-2014 05:51 PM
leaking kitchen faucet with sprayer Startingover Plumbing 2 10-02-2013 04:38 PM
loose Moen Kitchen faucet b lowell Plumbing 5 09-08-2013 09:41 AM
Single lever kitchen faucet (Moen) difficult to move repairlady Plumbing 2 03-02-2011 06:16 AM
