Modulating Tankless Water Heaters. I Am Shopping - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2014, 05:29 PM   #16
Rewards Points: 1,932
Been my experience when taking temperatures that the shower and tubs temps will fluctuate up and down up to 10 degrees F.
If someone also uses the hot it will again change. The units tend to either over compensate the gas and over heat the water. This is not fixable with anti scald tub/shower valves. Perhaps a good 1017 tempering valve may work.
Old 10-28-2014, 05:32 PM   #17
I would also like to mention that Rinnai and Navien only honor warranties when bought from a dealer of theirs and installed by a professional plumber who has been trained.
In other words you buy it from ebay or amazon your on your own. It voids the manufacture warranty.
Old 02-25-2015, 12:31 PM   #18
Rewards Points: 107
Noritz Brand
Originally Posted by jerzeedivr View Post
I have a Noritz NR98 DVC. It has the modulating gas valve commercial grade heat exchanger. No change in shower temp. Needs 1" gas supply reduced to 3/4" at unit. Also Stainless 2 way pipe.
Here in New Jersey water temp. in the winter is 38* F. You need to heat that to 115* F. Thats a 77* rise in temp. needed. Thats my coldest days.
jerzeedivr is offline   Reply With Quote
Info on tankless water heaters mrnighttime Plumbing 9 10-29-2014 02:35 PM
tankless water heaters gkaro Plumbing 17 02-25-2011 06:59 PM
Your take on tankless water heaters NowItsShowtime Plumbing 15 12-25-2009 10:17 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
