Mixing Type M And L Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2015, 10:16 PM   #1
Rewards Points: 369
Mixing type M and L copper pipe
Evening folks. Spent most of my life growing up on a well with a neutralization system to combat acidic water. Because of that experience I've always been told to use type L copper pipe for indoor work.
Flash forward to today where I own a house on city water. I don't know the PH but I would expect it to be closer to neutral. For my bath reno I went out and bought type L copper pipe like I always have. I came home and noticed that the whole house is done in type M. I know the fittings are the same between the types, is there a problem mixing the types? I suppose M has a slight restriction but I doubt it will be a real issue in real world performance.
I can't find anything in the codes that says I can't mix them was just wondering if there is something I'm overlooking.
info2x is offline   Reply With Quote
Old 02-13-2015, 10:39 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,008
No problem mixing them. They are sized by outside diameter so all the fittings will work on both.
The Following 3 Users Say Thank You to joed For This Useful Post:
info2x (02-14-2015), oh'mike (02-14-2015), Tom738 (02-14-2015)
Old 02-14-2015, 12:02 AM   #3
Rewards Points: 369
Ok. I knew they would join up. Just wanted to make sure that there isn't some kind of nuance that I wasn't aware of.
Old 02-14-2015, 05:36 AM   #4
Retired Moderator
Rewards Points: 7,174
No problem what so ever---glad to see you choosing the thicker type L---
info2x (02-14-2015)
Old 02-14-2015, 10:15 AM   #5
Rewards Points: 369
Thank you both. Time to start soldering!
Old 02-14-2015, 12:01 PM   #6
landfillwizard's Avatar
Rewards Points: 634
Go to a pool store and you can buy pH testing kits. Then you will know exactly what the pH is!
landfillwizard is offline   Reply With Quote
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
soft copper pipe issues fred54 Plumbing 7 04-02-2013 05:53 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
