Minimum Height Of Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2015, 09:59 PM   #1
Rewards Points: 225
minimum height of drain line
Want to run a 4" drain line for toilet waste to the 4" main stack of the house. The drain line would go into the stack about 1 or 2 feet above the basement floor where there is a 90 degree elbow that enters the sewer. Any minimum height requirement for this connection? Also, long sweep or sanitary tee to tie into the main stack? Thanks.
gt1935 is offline   Reply With Quote
Old 03-26-2015, 01:14 PM   #2
Rewards Points: 1,952
Any minimum height requirement for this connection? No. But you must have proper pitch to this point and your toilet will need to be vented by some means approved by your local code.
Also, long sweep or sanitary tee to tie into the main stack? Sanitary tee if in the vertical position only.
The Following User Says Thank You to Ghostmaker For This Useful Post:
gt1935 (03-26-2015)
Shower Drain min height? BNR34RB26DETT Plumbing 2 03-19-2015 06:36 PM
Disposer height above drain boogie81 Plumbing 10 10-15-2013 07:55 PM
Check Valve on Washer Drain Line jimbo12mx Plumbing 3 10-04-2013 06:55 PM
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 08:29 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
