Min Clearance Between Heating Fule Line And Hot Water Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By DR P
Old 02-02-2018, 09:53 AM   #1
Rewards Points: 14
Min clearance between Heating fule line and hot water pipe?
I am installing water pipes for a new washing machine. I am wondering if I need to maintain any minimum gap between the heating fuel line and hot water copper pipe. Thanks.
aplombDIY is offline   Reply With Quote
Old 02-02-2018, 10:19 AM   #2
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Min clearance between Heating fule line and hot water pipe?
not knowing types of fuel line piping nor plumbing piping makes this an unknown
but IMO there should be a true gap of some measure between both pipes to prevent other potentials also such as electrolysis as well as from heat.
In a residential setting, I would imagine that 1" thick code approved insulation for hot water piping would satisfy this if - properly secured to prevent slippage out of place
Peace
Bondo likes this.
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
