Merging Two 3" Waste Pipes, Etc - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2016, 01:16 AM   #1
Rewards Points: 1,178
Merging two 3" waste pipes, etc
We are installing two toilets on the second floor of a new house and I have a couple of questions. The two toilets are about 25' apart, and both toilet drain pipes will drop about 16-18" (top of flange to center-line of pipe) below the toilet flange. (1) Can we use a 3-3-2 wye to run the 2" vent pipe off the VERTICAL part of the 3" drain line, or does the vent pipe need to run off of the horizontal run? If only off of the horizontal run, we will use a wye lying at 45 degrees from vertical.(2) Can you run the 3" drain pipe down at 45 degrees (for 5 or 6') to drop it, or is it necessary to drop vertically via a long-sweep 90? (3) Where the two, 3" drain pipes meet, can one drop into the other via a 3" T-wye, or should they join via a wye in the horizontal position? Make sense? Thanks. john
Old 10-29-2016, 04:53 PM   #2
Rewards Points: 1,866
Re: Merging two 3" waste pipes, etc
Might help with an isometric drawing caz I can't make head or tails out of your paragraph. Sorry.
Old 10-29-2016, 05:00 PM   #3
I was afraid of that. I'll get a pic up as soon as I get back from work. Thanks. john
Old 10-29-2016, 05:27 PM   #4
Here are the questions I have. I hope the pictures are self-explanatory. Questions thereon. Thanks. john
Merging two 3" waste pipes, etc-question-1.jpg   Merging two 3" waste pipes, etc-question-2.jpg   Merging two 3" waste pipes, etc-question-3.jpg
Old 10-30-2016, 12:25 AM   #5
I think we can forget the third question. Of course I can vent off the vertical line, using a sanitary T. Never mind. cheers. j
Old 10-30-2016, 01:02 AM   #6
As for question 2, apparently a 45 degree drop is considered vertical in the code book and is fine.
Looking for advice on these waste pipes costgeek Plumbing 2 05-19-2016 04:13 PM
Insulating attic pipes thew60 Insulation 4 01-10-2014 02:23 PM
copper pipes gt1935 Plumbing 6 12-28-2013 06:21 PM
Did I just ruin my copper pipes with steel wool? ghutch Remodeling 1 10-09-2013 07:02 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
