MBR Shower Hot Water Volume Slows To A Trickle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2016, 01:07 PM   #1
Handy homeowner
RKennethBauer's Avatar
Rewards Points: 4
MBR Shower Hot Water volume slows to a trickle
The hot water just dribbles out. Shower cold water can be full volume - doesn't appear to be a shower head issue. Both sinks in the master bath produce high volume hot water, warm in 15 seconds, too hot for your hand in 25 seconds. I have removed the HW ceramic cartridge a Grohe 45 883 000 and examined. Seemed to have some flecks in the fins. Blew it out, replaced, voila! full volume hot water. For a while. Days and showers later, same trickle. Suspect cartridge end seal washer of deteriorating, creating the flecks. Replace cartridge with new one. Same pattern of starting with full volume but volume falls even more quickly this time. It seems that just removing and replacing the HW cartridge remedies the situation for a few showers, but I'm getting tired of doing that!
Other info that may apply. We have hard water and no water softener. The shower in question is at the opposite end of the house from the hot water heater, about 80' with other baths, sinks etc in between. There is a hot water recirculating device next to the hot water heater that is a couple decades old, and runs full time, but I would guess that it is for the entire hot water line, not just the master bath shower.
Ideas? Thanks in advance for your interest and help.
Ken
RKennethBauer is offline   Reply With Quote
Old 06-15-2016, 01:12 PM   #2
ZTMAN's Avatar
Rewards Points: 628
Re: MBR Shower Hot Water volume slows to a trickle
Based on what you are describing, I would flush the line. Remove the cartridge, turn on the water, with someone holding a cup over the stream shooting out . Let the line clear itself and reinstall the cartridge
ZTMAN is offline   Reply With Quote
Old 06-15-2016, 02:55 PM   #3
Handy homeowner
Rewards Points: 4
I forgot to mention that I did do this. Turned off the house water, removed the HW cartridge, turned house water back on full and shot about three gallons into the shower. Did this when I installed the new cartridge - didn't help.
Could it be an air pressure type of thing? Like something needs to be bled?
Thanks.
Ken
Tags
hot water doesn't last
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
