Master Bath Shower Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By DR P
  • 1 Post By Marson
Old 02-02-2018, 10:41 PM   #1
Rewards Points: 36
I just bought new construction. The master bath shower is fitted with Danze fixtures that consist of a rain shower head, hand held shower head on sliding bar, thermostat knob , and (2) separate on/off knobs for the two shower heads. I want to replace these fixtures with Köhler that better match the sink hardware. Is this an easy remove and replace or will it entail cutting out some tile and drywall to change our fittings?
Phickman1 is offline   Reply With Quote
Old 02-02-2018, 11:44 PM   #2
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Master Bath Shower Fixtures
Be more cost effective to:
change out lavatory faucets to match shower
Be whole lot more cost effective to:
recognize that shower system doesn't have to truly match lavs
Price up the cost of the new Kohler shower system desired
you will need new rough in valves & all the trim for a true cost
Double that price for labor cost to re-plumb your existing shower
round up to at least next grand to accommodate tile demo/replacement
wild card factors: new sheet rock, paint, loss of use, construction delays
but it's your money - do what you want to do
Peace
MTN REMODEL LLC likes this.
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 02-02-2018, 11:45 PM   #3
Rewards Points: 1,264
You're probably out of luck there. Obviously you could change the shower heads, but the trims (i.e. the part you see) on the shower valves will not be interchangeable. Perhaps you can find some Danze handles etc that are suitable?
DR P likes this.
Marson is offline   Reply With Quote
Old 02-03-2018, 06:22 AM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,698
Yep.This is a decorating issue not a plumbing question.
TarheelTerp is online now   Reply With Quote
Old 02-03-2018, 08:21 AM   #5
Rewards Points: 36
Unfortunately it is for a clent who insists on changing out he shower fixtures on new construction. The developer changed the sink fixture but refused the shower request even though they haven’t tiled yet. I was just trying to see how much of an expense they will incur. The rain shower head should be just a swap out as well as the head of the hand shower. They’ll have to accept the knob fixtures. This sounds like their least expensive option. Thanks for the replies.
Bath vent in shower s4alex Tiling, ceramics, marble 1 10-09-2016 09:30 PM
Installing bath and shower mixer valve... thomasl12 Plumbing 10 04-02-2015 07:20 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Replacing fixtures and CVPC in shower pinkertonpv Plumbing 1 07-30-2009 06:18 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
