Master Bath Remodel - Need Some Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2016, 01:37 PM   #16
Rewards Points: 30
Re: Master Bath Remodel - need some help
Tks Javilies, I understand that, the industry I am in is like that as well, seems like anytime you deal with any regulations that the gov't is involved in its more of a good luck situation.
When I was young I was fortunate to help out my grandfather and others building houses, moving houses all sorts of crazy stuff, even did a little cabinet making, but that was too many years ago, but I think it was enough to curse me with the "I wanna do it" mentality. Of course that bites me in the butt sometimes but its all part of the learning process. I'm the type of person that cannot stay idle so I always have a project going on slowly making the old house a bit better as I go.
As far as kiss a plumber, if my plumber looked like that, oh yeah!!!!!
alaska_av8r is offline   Reply With Quote
Old 03-18-2016, 01:43 PM   #17
Rewards Points: 30
Okay I think I have this laid out like I need.
I have the 2" shower p-trap going under shower wall with a 2x2 wye and 45 for vent, then going on to a 3x2 wye to connect to 3" from toilet.
From toilet a 3" flange to a 3" closet bend to a 3x2 wye (slightly rotated) for vent to run back behind toilet and up toilet wall, vent will use 45's until above in ceiling
Master Bath Remodel - need some help-piping01.jpg   Master Bath Remodel - need some help-piping02.jpg
Old 03-18-2016, 01:50 PM   #18
Rewards Points: 30
My next question is a cleanout, that hot water heater is going away for a tankless, can I and should I use a wye below the toilet to make a cleanout that I could access by pulling up floor in the closet behind the toilet?
Old 03-18-2016, 04:30 PM   #19
Rewards Points: 1,938
The toilet itself is considered a cleanout. I would leave it at that.
Old 03-18-2016, 10:08 PM   #20
Rewards Points: 30
Ty Ghost, have a good weekend
Old 03-19-2016, 02:41 PM   #21
Your dry flat vent on the toilet is also a code violation. On the picture with the water heater.
Old 03-19-2016, 08:25 PM   #22
Rewards Points: 30
The one i have drawn in yellow near the closet bend? This is where I got that idea from since I don't have a wall for that vent to go straight up. http://www.diyadvice.com/diy/plumbin...in-vent-lines/
Old 03-23-2016, 10:17 AM   #23
Rewards Points: 30
Pex? The bathroom is currently plumbed in copper pipe but Pex is allowed here so which would you go with as far as pros/cons?
Old 03-24-2016, 11:02 AM   #24
You cannot run any portion of the vent of any fixture below the fixture horizontal at all.
905.4 Vertical rise of vent. Every dry vent shall rise vertically to a minimum of 6 inches (152 mm) above the flood level rim of the highest trap or trapped fixture being vented.
So you need to use a different venting method.
Your DIY reference is not to the IPC.
I'm a plumbing inspector in a IPC state. With 28 years in trade experience as a plumber.
Old 03-25-2016, 03:06 PM   #25
Rewards Points: 30
Thanks Ghost for clearing that up for me, would the 2" vent on the shower drain line be enough of a vent for it and the toilet, the toilet will be about 6 linear pipe feet away from the shower vent going up through the wall.
Old 03-26-2016, 11:02 AM   #26
Please just draw an isometric of your intent. Your pictures are just confusing me.
Old 03-27-2016, 03:56 PM   #27
Rewards Points: 30
In this image it shows the 2" vent for the shower that goes up the wall, where the toilet sits I cannot vent it because it passes under a door and not a wall. The distance from the toilet to the vent on the shower will be about 5-6 feet.
Master Bathroom Remodel, question with pictures! PolySuperman Kitchen & Bath Remodeling 4 06-17-2014 10:46 AM
Master Bath Remodel ScottFla40 Kitchen & Bath Remodeling 9 06-30-2013 07:52 PM
My Master Bath FULL Remodel. -LOTS- of pics. 1st_House Project Showcase 6 06-30-2009 10:12 AM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 07:37 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 03:16 PM
