DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Master Bath Remodel - need some help (https://www.diychatroom.com/f7/master-bath-remodel-need-some-help-377058/)
alaska_av8r 03-14-2016 07:21 PM
We are remodeling our master bath and I want to do as much of it myself as I can, not only to save money but I enjoy projects like this. I have a code book but getting the big picture is still tough.
Here is what we currently have. As you enter the room, on the left you will see where the vanity was, next was the toilet and the main stack, then further down was the shower. There was nothing but a closet on the right side of the room, it did not have a shower.
alaska_av8r 03-14-2016 07:29 PM
Re: Master Bath Remodel - need some help
wow two issues the server running this forum is lagging bad, another issue, is the only way to post images with a hosting server, I don't use photobucket or anything like that and normally can just upload images or add them as an attachment but I don't see either option?????
alaska_av8r 03-14-2016 07:31 PM
and I can't edit my own message...
TheEplumber 03-14-2016 08:13 PM
199 Attachment(s)
Welcome to our forum!
A couple things first to get you going-
Be sure you have replied to the email to confirm your membership- check your spam folder
Check the tutorials here for attachment help- http://www.diychatroom.com/f114/
The edit button only works for a few minutes- we have our reasons for that :wink2:
A lot of good, helpful folks here wanting to help so keep at it
Javiles 03-14-2016 11:46 PM
I love it when homeowner start by,, I Bought a code book for my DIY projects.
alaska_av8r 03-15-2016 11:28 AM
Thank you eplumber thats what I missed, I run a vbulletin forum as well and not sure how i missed that, but that took care of it.
I take it then from Javiles comment that I am on the wrong forum? I thought from the name that it would be where a DIY could ask questions but I guess I was wrong.
TheEplumber 03-15-2016 11:40 AM
199 Attachment(s)
Nope, this is a DIY site. You can ask all your questions here - you may not like the answer sometimes though :)
Pictures, drawings and your local code specs are helpful to us when we respond.
Ghostmaker 03-15-2016 11:59 AM
Alaska follows UPC hopefully E plumber can help you. I only help with IPC code.
alaska_av8r 03-15-2016 12:47 PM
5 Attachment(s)
Thanks guys,
I am now in Mississippi and live in the county so they follow 2012 IPC. The bath I am wanting to remodel is on the second floor.
In smallbath01 it shows the original plumbing with a vanity drain on the left, toilet in middle and tub on the right, the master bath never had a shower. The lines show where the plumbing is hidden by the floor.
I would like to move the toilet to the other side of the room about 10' away and add a shower on that side as well. In the second attachment I was thinking of moving the vanity plumbing into the wall to tie in to the main stack, then the yellow shows the 3" continuing to the toilet across the room, and the green shows where the tubs plumbing will be extended.
In the third attachment you can see the yellow 3" for the toilet, then the blue showing where the shower drain 2" will come in.
The fourth shows the shower location and the line in red is a proposed 2" vent. Currently the only vent at all is the main stack.
The fifth attachment shows the proposed path of the 2" vent going back across top of the room to tie in to the main stack.
If you see anything I may have missed don't hesitate to point it out but my main question is does that plan make sense, and instead of venting the shower and toilet individually can I vent them using the single 2" shown in red. Also what I can't quite figure out is what I will need to do where the shower, toilet and vent tie in.
Thanks in advance...
tim
ddawg16 03-15-2016 12:56 PM
Welcome to the forum.....most of us were in your same shoes at one point.
So...you fly in Alaska....but not the AV8 Harrier? Bush pilot?
Getting back on topic.....we need a question.....
alaska_av8r 03-15-2016 01:06 PM
tks ddawg, I was a bush pilot in alaska so I flew the bug fighters not the real ones (no AV8's or F's, more like a C what I flew was so slow a bug would hit you in the butt) but now I live in northern mississippi.
Ghostmaker 03-15-2016 04:37 PM
Some one hacked up your original install. Glad your cutting it out. Your under IPC code. Attach the lavatory as drawn. Remove all sanitary tees not installed in a vertical position.
You will need a wall for the shower vent. You cannot vent anything under the floor. All vents must rise vertical {Up and down} at least 6 inches above the highest flood level rim (the toilet} prior to turning horizontal.
You will need 3 by 2 wye for the shower and a wall to run under before you pick up the trap. There is no fitting as you have it drawn. You must use a long sweep 90 on the toilet 3 inch when turning horizontal to horizontal or a st 45 and reg. 45 fitting (same thing). From toilet toilet flange 3 inch st. 90 long sweep 90 then 3 by 2 wye with a vent on the shower. This is called a wet vent. You will need permits and inspections if your locality require this.
If you have any more S type traps in your house you should plan on redoing them they all are illegal.
Also don't forget to perm cap that unused 2 inch. Use a scd 40 cap. Make sure you use primer and glue on all joints. Scd 40 white PVC only No mixing of plastics.
All your floor joist your running the 3 inch for the toilet through will need to be beefed up.
alaska_av8r 03-15-2016 08:38 PM
Thank you Ghostmaker great info and that answered most of my questions, yes they did a hack job for sure.
Javiles 03-15-2016 09:05 PM
Not personal Its funny because i know plumbers that cant interpret the code book, in fact i know a few inspectors that cant find the gray areas. you're at the best DYS site these guys here are sharp good plumbers, and good hearted they take the time to help others and they usually never get a thank you. so lets make this kiss your plumber month.:kiss:
ben's plumbing 03-15-2016 09:29 PM
1 Attachment(s)
I only kiss a plumber if hes better looking than my wife...
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
