Master Bath Re-model - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2015, 08:02 PM   #1
Rewards Points: 18
Master bath re-model
Hello , I am looking for some help with confusion on plumbing drains and slope. I am relocating an old single sink vanity from one wall and making it a two sink vanity on a wall 90 Degree from old . Total length of drain line would be approx. 6 feet on new wall, make a 90 degree turn and run about 6-8 feet to the existing waste pipe. Do you still maintain 1/4" slope from beginning to end. And if so , wouldn't this put the p trap outlet more than the 1 1/2" pipe diameter below the waste input? Any suggestions?
jechadell is offline   Reply With Quote
Old 01-03-2015, 08:38 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 286
Yes, it would. You will need to revent the waste line serving the sink. The revent can connect to your vent stack- usually at 42" above the floor
Also, the 90* turn at the corner will need to be a long sweep 90 or 2- 45's joined together to make a 90
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-03-2015)
Old 01-03-2015, 08:48 PM   #3
Rewards Points: 18
."You will need to revent the waste line serving the sink. The revent can connect to your vent stack- usually at 42" above the floor""
I don't exactly know what you mean by reventing at 42".. I am working on getting some photos uploaded and may help clarifying it.
The Following User Says Thank You to jechadell For This Useful Post:
Old 01-03-2015, 10:55 PM   #4
Rewards Points: 582
what he means is after you run your new drain you would also have to bring a vent from new drain starting at least 42" off floor back to existing vent...
Old 01-04-2015, 12:05 AM   #5
Plumber
Rewards Points: 286
Heres a quick sketch- this is just one possible route for the vent.
BTW, you must be 1/4" per ft on the drain line
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-04-2015), jechadell (01-04-2015), tylernt (01-05-2015)
Old 01-04-2015, 10:57 AM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
For every foot of line you run you'll need to drop 1/4 inch per foot from the trap ware to the vertical drop i only mention this because if you have a low sink combo you'll have a problem with your drain/trap/pop up assembly, a common mistake most make on a relocation seen lots of plumbers make these mistake homeowners are forgiven not professional plumbers shame on them.
now depending on the size of your line and your code you'll to re vent every x amount of feet from the trap and the vent must be above the rim line / flood line of the servicing sink
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
master bath make over ideas ggold Plumbing 3 03-31-2012 09:36 PM
Doms new master bath dominic58 Plumbing 0 09-29-2011 01:00 PM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 07:37 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 03:16 PM
