Master Bath Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By KyleB
  • 1 Post By TheEplumber
  • 1 Post By Ghostmaker
Old 05-16-2017, 03:13 PM   #1
Rewards Points: 40
master bath plumbing question
I am currently renovating my MBR and have a plumbing question. The bathroom currently has one sink. The 3" drain/vent stack is located between the toilet and the existing sink. For reasons I won't go into, relocating the drain is not an option. I am adding a second vanity and sink, so I will basically have two sinks to the right of the drain. That's problem #1.
Problem #2 is the house was built in 1979, and all of the plumbing is ABS. ABS isn't sold anywhere around here anymore, so my new plumbing will have to be PVC. I was hoping someone could take a look at this diagram I drew up for how I think I can achieve what I'm trying to do. I think my best approach would be to do all of my new plumbing in PVC and connect my new work to the old work with a fernco, FL code doesn't allow for using ABS to PVC transition cement even on DWV pipes.
Thanks for looking and I'm open to any comments or suggestions.
[IMG][/IMG]
KyleB is offline   Reply With Quote
Old 05-16-2017, 06:24 PM   #2
Rewards Points: 898
Re: master bath plumbing question
Why don't you order the abs fittings you need?
BIG Johnson is offline   Reply With Quote
Old 05-16-2017, 06:33 PM   #3
Rewards Points: 40
ABS isn't available here any longer, likely because it emits hydrogen cyanide if it ever catches on fire. I have new runs of drain pipe off of the lavs also, and FL code prohibits solvent welding PVC to ABS. So even if I could find the proper ABS fittings, it wouldn't do me any good since straight runs of ABS are nowhere to be found. That's why it made sense to me to do all new plumbing in PVC and just connect to the ABS drain with a fernco.
Anyone else care to give the thumbs up or thumbs down on my diagram?
Old 05-16-2017, 06:50 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 900
Delete
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-16-2017, 08:15 PM   #5
Rewards Points: 1,952
Only use a proflex band from pvc to abs not a all rubber fernco.
Upper tee must turn to roof. That vent pipe needs to be 42 inches to center or higher in the horizontal. 6 inches above your sinks flood level rim is normally 42 or better.
Old 05-16-2017, 08:54 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,886
Recognising I AM NOT A PLUMBER, and I don't know if your a upc or irc... as if I even knew the difference...
Couple of comments, your top wye on the vent stack (or santee) is upside down.
Your venting of the sink on the right needs to be on a trap arm.
(I can't enlarge the pic, so I can't read pipe sizes etc and tell exactly what I'm looking at and made some assumptions )
And I think the steel jacketed Fernco is required coupling from PVC to ABS.
I'll await for our very good pro's to come along. THIS IS A GUESS
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 05-16-2017, 09:52 PM   #7
hkstroud's Avatar
Rewards Points: 6,694
Should be able to do this.
You have 8 foot to vent with 2" drain.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 05-17-2017, 06:25 AM   #8
Rewards Points: 40
Thanks for the responses everyone. Yes, I see now that my upper santee is upside down, thanks! Also, yes I am planning on using a shielded coupler, not all rubber.
hkstroud, I was always under the impression that you can't have two sink basins inline like that on one drain pipe, am I wrong about that? If it's OK, that would make this job a lot easier. I assume if I did it like that I'd need to still add a second vent for the second sink. Both sinks with be within about 30 inches of each other O.C. My total run from lav 2 to the drain is about 5 feet, so I have more than enough leeway in terms of length to work with.
MTN REMODEL LLC likes this.
Old 05-17-2017, 06:54 AM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 290
The lavs in the picture will not pass any codes I have worked with. Follow Ghost's directions listed above and you should be fine
SHR Plumber likes this.
The Following User Says Thank You to TheEplumber For This Useful Post:
SHR Plumber (05-18-2017)
Old 05-17-2017, 07:53 AM   #10
Rewards Points: 40
Thanks for the response. Which lavs won't pass code, my diagram or the actual picture from above? I always thought having two waste arms inline on one drain pipe like that would lead to a siphoning effect if you were running the water on lav 2 past the arm for lav 1; i.e. you'd suck all of the water out of the P trap on lav 1 if you were using lav 2.
Old 05-17-2017, 09:11 AM   #11
Plumber
Rewards Points: 290
Your drawing is a correct method.
As shown in the picture will not pass inspection in my area
Sent from my XT1650 using Tapatalk
Old 05-17-2017, 09:53 AM   #12
Rewards Points: 40
Thank you everyone for the responses.
Old 05-17-2017, 04:35 PM   #13
Not legal stroud. You have 1 unvented trap passing another trap in the horizontal. Now if you placed a vent in between the two traps it might be legal circuit vent or common vent but your other minor issue is improper use of fittings using a sanitary tee in the horizontal picking up a trap.
If you wish to do it this way you need to use a wye and a 45 on the first sink trap then a vent on a sanitary tee then a 90 for the second sink trap. You must vent in between the two traps.
Master Bath gut - advice? iowaDIYgal Kitchen & Bath Remodeling 2 03-13-2014 10:03 PM
Need some help with heat in my master bath johnvosh HVAC 13 01-05-2014 09:42 AM
Three separate light switches in master bath are inoperable BuckWinig Electrical 3 02-16-2013 07:56 AM
master bath needs a separate shower pypeke Plumbing 7 09-02-2012 12:02 PM
30 year old home needs master bath remodel/addition. Eaglepose Kitchen & Bath Remodeling 2 03-26-2012 09:07 PM
