Mansfield 160 Fill Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2015, 07:18 AM   #1
Rewards Points: 1,058
I have to replace one of these. I tried to adjust the water level and the screw just stripped out.
I would have to order one. Or I can buy a "universal" fill valve at Lowes. Do I have to get a Mansfield, or will one from Lowes do it.
If one from Lowes will work, the Korky or the Fluidmaster?
Toller is offline   Reply With Quote
Old 01-04-2015, 07:33 AM   #2
Rewards Points: 582
fluidmaster should work...
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (01-04-2015)
Switching to a fluidmaster fill valve inside an old briggs tank. pinecone12 Plumbing 8 01-20-2012 02:30 PM
Humidifier fill from float valve? Devil505 Plumbing 2 12-10-2011 12:23 PM
Toilet fill valve "refluxes" lison Plumbing 3 11-04-2011 10:16 AM
Leak from fill valve? princessme Plumbing 6 03-28-2009 07:00 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
