MAJOR Problem With Upflush Toilet In Basement Bathroom. Please Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2014, 04:18 PM   #1
Rewards Points: 2
Exclamation
MAJOR problem with upflush toilet in basement bathroom. Please help!
I have an up flush toilet in my basement bathroom. It got clogged two days ago, and I've tried everything I've done in the past, but nothing has worked (plunged, snaked, checked breaker). The bowl AND bathtub are now both full of sewage...one more flush and I'll be wading through it! Please, someone help! I am clueless about these things. Many thanks in advance!
MamaKnDaddyD is offline   Reply With Quote
Old 11-10-2014, 05:31 PM   #2
Rewards Points: 1,952
Apparently the grinder pump in the toilet is bad. Also make sure your breaker hasn't tripped to the pump.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
Javiles (11-10-2014), MamaKnDaddyD (11-10-2014)
Tags
basement bathroom , sewage , upflush toilet
Adding Basement Bathroom. Rear discharge toilet install question paulyjsob Plumbing 9 08-16-2014 01:59 PM
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 08:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
