Major Leak Under My Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2016, 06:26 AM   #1
Major leak under my kitchen sink
I'm in desperate need of assistance with a very bad leak under my kitchen sink. I'm a new homeowner so basically all of this is new to me since I'm also recently widowed. The leak is coming from the metal pipe that attaches to the PVC pipe. I took the PVC pipe apart and the metal pipe has a hole in it. It looks like it might be possible to unscrew the metal pipe, but since this is the first time I've ever touched anything plumbing wise, I am afraid to proceed without advice. I can't afford to pay anyone to help me. I have a video and some pictures, I'll see what I can post. I appreciate any help anyone can give. Thanks Jmon for telling me to start my own new thread. Advice on what to do to start to fix the hole/problem would be appreciated, since apparantly my washer, dishwasher and sink all drain through this pipe. Thank you so much to anyone who is willing to help me.
Urmy is offline   Reply With Quote
The Following User Says Thank You to Urmy For This Useful Post:
jmon (03-15-2016)
Old 03-13-2016, 06:28 AM   #2
Photos of my problem
Major leak under my kitchen sink-img_20160312_212559_1457868446654.jpg   Major leak under my kitchen sink-img_20160312_212336_1457868480725.jpg
Old 03-13-2016, 06:46 AM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Re: Major leak under my kitchen sink
you need a few more pictures of more of the metal pipe..do you know how to use or have a sawsall?
WhatRnsdownhill is offline   Reply With Quote
Old 03-13-2016, 06:49 AM   #4
Rewards Points: 468
It looks like the metal pipe was corroded by hard water. If that is the case, a water softener may be an investment worth considering. The pics are very zoomed but it looks like we are dealing with drain plumbing right? That's low pressure so generally an easier DIY fix. Those parts need to be replaced and preferably with PVC. It's hard to tell from the pictures but you may get away with cutting away the corroded thread and adapting new PVC to the metal (copper?) end. Fernco makes silicone adapters with hose clamps on both that you should be able to find at your local hardware or Home Depot that will let you attach copper drain pipe to PVC. Any patch job you do on that will be very temporary.
Jim F is offline   Reply With Quote
Old 03-13-2016, 07:27 AM   #5
An old Tradesmen
Rewards Points: 9,224
Moved to plumbing forum.
Old 03-13-2016, 07:30 AM   #6
Rewards Points: 18,794
Very common problum with old steel pipes.
The parts called a pipe nipple.
It's tricky to get that old one out, most likely it's going to crush or snap off when you try to remove it.
I'd remove that trap adaptor (that white PVC piece) and use my sawsall with a short Bimetal fine tooth blade to make two cuts on the inside of the pipe so the nipple can be broken in two to get it out being careful not to cut into the threads in the elbow to deep.
Once it's out clean up the threads with a wire brush.
It has nothing to to with the water being hard, all steel pipe rust out from the inside out and the threads are the weakest area and will fail first.
No way is a Fernco going to fix this one.
oh'mike (03-13-2016)
Old 03-13-2016, 08:42 AM   #7
Retired Moderator
Rewards Points: 7,174
Joe laid out the simplest fix--if the threads inside that T are salvageable--
If they are not---you may need to open up the cabinet back and plaster to expose the drain pipe and vent pipe.
After you do that, post a picture and one of us can walk you through the task of cutting out the old T and replacing it with PVC.
Old 03-15-2016, 03:25 PM   #8
I'm obviously way out of my league here. I don't even know what a sawsaw is. I'm trying! I'm taking your comments and suggestions to people who can see my photos and it seems hopeless.
Old 03-15-2016, 04:27 PM   #9
Rewards Points: 1,860
Call a plumber.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (03-15-2016), r0ckstarr (03-16-2016)
Old 03-15-2016, 05:30 PM   #10
Super Moderator
Gymschu's Avatar
Rewards Points: 510
Here's a "sawsaw" (Sawzall) to help get you started......
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 03-15-2016, 06:23 PM   #11
Rewards Points: 28
yes, cut out all the old stuff
bluegroove is offline   Reply With Quote
Old 03-15-2016, 06:24 PM   #12
Retired Moderator
It is not a sign of weakness to call in a pro----
I'm lost with computers--I hire out the repairs----
no need to 'tool up' for a one time job--or learn all of the skills.
Old 03-15-2016, 07:11 PM   #13
Rewards Points: 82
You need to replace the threaded corroded pipe. You should buy a new pipe in hardware store, aside from you should have any pipe cutter, super glue for pipe, pipe sealant or tepdon tape. Then install it properly to prevent any kind of leak from the pipe.
Hopefully this video helps.
cmorales is offline   Reply With Quote
Old 03-15-2016, 07:44 PM   #14
Does anyone have any idea how much this might cost to get repaired? The video was very helpful. I just need the pipe that goes into the wall fixed/replaced. I really appreciate all of your help. Maybe I can borrow the money. I don't have any of the more serious tools that this would require. I guess I'm going to have to call a plumber, but I need an idea of how much money I'm going to need.
Old 03-15-2016, 08:31 PM   #15
so you buy a house but have no money for repairs???
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 10:29 PM
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
