Main Water Valve Very Difficult To Turn - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By diy2017
Old 08-19-2017, 07:17 PM   #1
Rewards Points: 28
Main Water Valve very difficult to turn
I have a hard time shutting down my main water valve.
In fact, I am having a problem turning it back to the horizontal position. If I try any harder, I am afraid I will break it and make a big mess.
I have water as is. But I really want to be able to shut it down when I need to fix things in the house.
Any ideas?
diy2017 is offline   Reply With Quote
Old 08-19-2017, 07:38 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,572
Re: Main Water Valve very difficult to turn
Spray a bit of lube on the shaft. A ball valve shouldn't have the same proclivity to bind up that a gate valve does
Old 08-19-2017, 08:26 PM   #3
Rewards Points: 3,496
+1
Try working it back and forth a little more each time so you don't break anything. It's probably just frozen/stiff from lack of use. Happens all the time.
After you get it working properly, exercise it a couple times a year.
jmon is online now   Reply With Quote
Old 08-19-2017, 08:31 PM   #4
Rewards Points: 60
Will WD40 work?
dws780 is offline   Reply With Quote
Old 08-19-2017, 08:35 PM   #5
Yes, that should do it. Most people have that on hand.
Old 08-19-2017, 09:42 PM   #6
Rewards Points: 28
Thanks guys. I gave it a little bit more force and it worked. I guess I was too afraid to break it.
jmon likes this.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
