Main Water Shut Off Not Working Properly - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2015, 02:09 PM   #1
Rewards Points: 127
Main water shut off not working properly
Hello,
The main water shut off valve does not completely shut off the water when it is completely closed. I turn it as far as I can and water still trickles from the faucets upstairs. I attached a picture of the valve. Can this valve be repaired or would it be better to have it replaced with a ball valve? The house was built in 1983 so I'm assuming the valve is as old as the house. I "exercised" it a few times (shut it off and on several times) and this did nothing.
Thanks for the help.
P.S. Sorry about the rotated pic. No matter what I do I can't get it to the correct orientation.
wkumtrider is offline   Reply With Quote
Old 10-18-2015, 02:21 PM   #2
Rewards Points: 6,620
If it were mine I'd attempt a repair first being it's soldered.
Old 10-18-2015, 02:27 PM   #3
Rewards Points: 19,008
If it was mine I'd be installing a ball valve.
No need to remove the old one if there's an easier area to work from.
A repair coupling looks like a regular coupling but has no hub on the inside so it can be slid over the pipe.
jmon (10-18-2015)
Old 10-18-2015, 02:30 PM   #4
Rewards Points: 1,952
Install a shark byte ball valve upstream of it.
The Following User Says Thank You to Ghostmaker For This Useful Post:
jmon (10-18-2015)
Old 10-18-2015, 04:07 PM   #5
Rewards Points: 127
Thanks guys. There is not enough room to install one upstream, but plenty of room downstream.
Old 10-18-2015, 05:06 PM   #6
Opps I ment downstream...
Old 10-18-2015, 05:18 PM   #7
Rewards Points: 582
can you get us a picture further away...if it was mine ..shut off water at street replace with full flow ball valve...don't like shark bites...sorry...
The Following User Says Thank You to ben's plumbing For This Useful Post:
jmon (10-18-2015)
Old 10-18-2015, 05:23 PM   #8
Rewards Points: 8,749
Turn it off at the meter and replace the washer.
As for pictures always crop them to be wider left to right. I've gone a far and dropping a skinny one on a white background before posting.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 10-18-2015, 06:50 PM   #9
Rewards Points: 127
Here is another angle. To the right of the valve is where the water comes in (where the grounding clamp is attached). The valve is right off a 90 elbow, and then turns down into the concrete wall. Very little room to add another valve there. Plenty of room after the valve.
Old 10-18-2015, 07:14 PM   #10
Rewards Points: 3,512
It may not be the best solution, but combine post 3 and 4, and there is your quickest and easiest fix. Imo.
No need to remove old valve, just turn off valve, cut/deburr pipe, replace with a full port sharkbyte ball valve. Done. Doesn't matter about the dripping water no need for any soldering. Use a bucket to catch the water, should only take about 5 minutes.
The better but more involved fix would be to replace it with a full port soldered ball valve as suggested in post 7. You may have to get your water district and a local certified plumber involved if you do not have the skills for this fix.
jmon is online now   Reply With Quote
Old 10-18-2015, 07:19 PM   #11
Rewards Points: 48
Isn't that a packing nut below the hand valve? did you try tightening it? crank down on it a bit and see if that helps you.
cmcnick is offline   Reply With Quote
Old 10-18-2015, 07:20 PM   #12
Rewards Points: 48
Old 10-18-2015, 07:21 PM   #13
Btw, that one 3/4in copper pipe on the left in the wall looks kinked/bent pretty bad. What happened there. I would replace/fix that as well while you have everything open. Just a suggestion.
Old 10-18-2015, 07:49 PM   #14
Rewards Points: 48
Nice catch! I completely missed that.
The Following User Says Thank You to cmcnick For This Useful Post:
jmon (10-18-2015)
Old 10-18-2015, 07:55 PM   #15
I saw that but thought OH Well, just looks a little non professional.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
jmon (10-18-2015)
Service pit for main water supply and sewer line sonnaps Plumbing 3 07-23-2015 10:54 AM
Cannot identify main water shut off in home. tashinaj Plumbing 17 12-19-2013 11:35 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
