Main Water Line Basement Entrance - Does This Look OK? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2016, 06:59 PM   #1
Rewards Points: 80
Main Water Line Basement Entrance - Does this look OK?
I've attached a picture of where my main municipal water line enters my basement through the floor.
I don't have any problems with it, but until recently the hole was sealed by some packed in rags covered in spray foam... this was not great to look at so I figured I would investigate. I believe this was the result of the installation of the ball valve. Does this connection look ok?
I'd also add that at the bottom of the ball valve there appears to be some green corrosion, which seems to be from water condensing on it? It is winter here, so the incoming water is cold, is this normal?
This brings me to the real question, which is what is the best way to seal this up? I was thinking maybe some gravel and then a very thin layer of cement so that if one needed access to this pipe under the floor that it would be relatively easy.
I think it's a lead pipe, is there anything I should be careful with as far as chemical interactions between the pipe and concrete?
Thanks.
Main Water Line Basement Entrance - Does this look OK?-img_20161125_150250.jpg
indigo is offline   Reply With Quote
Old 11-25-2016, 08:29 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,682
Re: Main Water Line Basement Entrance - Does this look OK?
The hole should be clean up a bit and filled with concrete or hydraulic cement.
I can't tell for sure the fittings look low. They should not be buried in the concrete.
Old 11-25-2016, 11:03 PM   #3
Rewards Points: 80
Here are some additional pictures.
Main Water Line Basement Entrance - Does this look OK?-img_20161125_224229.jpg   Main Water Line Basement Entrance - Does this look OK?-img_20161125_224239.jpg   Main Water Line Basement Entrance - Does this look OK?-img_20161125_224355.jpg
Old 11-25-2016, 11:23 PM   #4
Super Moderator
joed's Avatar
Is that a copper line connected to a galvanized nipple to the valve?
Old 11-26-2016, 08:09 PM   #5
Rewards Points: 18,806
100% of the time those old steel pipes are going to fail at some point and leak at least.
Mine collapsed completely.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
