Main Water Control Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2016, 09:01 AM   #1
Rewards Points: 740
Main water control leaking
The main water supply line comes up from the ground, through my crawl space, and into the utility room. The first shut off valve is leaking a little when the water is shut off. The pipe then goes to the meter from the main leaky shut off valve. According to the city this valve is still my responsibility. Obviously I will have to have the city turn off the water in the front yard. Is there any trick to replacing the main valve? I planned to just cut the pipe, and either sweat on or sharkbite on a new ball valve. Yes?
crescere is offline   Reply With Quote
Old 04-09-2016, 10:56 AM   #2
Rewards Points: 1,852
Re: Main water control leaking
If it is leaking a little turn off the water as much as possible and just cut in a sharkbyte ball valve downstream.
Old 04-09-2016, 11:09 AM   #3
Rewards Points: 18,762
Where's it leaking?
Around the seam, if so try snugging up the packing nut a small amount.
Old 04-10-2016, 08:14 AM   #4
Rewards Points: 740
Here is a picture of the stem coming up from the crawl. It has water dripping along the side. I do not know what all that black stuff is. It feels like tar.
Old 04-10-2016, 08:18 AM   #5
Rewards Points: 740
Overall picture of meter and valve
Main Water Valve shut off, water still running diy5781 Plumbing 9 03-24-2013 12:40 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 09:30 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
