Main Floor Bathroom Addition Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2017, 07:02 PM   #1
Rewards Points: 2
main floor bathroom addition question
Hi there just a quick question!!
I'm looking into adding a bathroom on my main floor, and the only thing holding me back at this point is the plumbing, I can do all the other work myself!
Is it up to code to tie into my existing stack at its clean out with a Y and include a new clean out for my new toilet. I'm going to redo my shingles this summer so ill install a new vent for the bathroom at that time, just trying to figure out this toilet situation, i can hammer the slab if this is not possible, but just trying to figure out the easiest way that's up to code.
I live in ontario
dprovost is offline   Reply With Quote
Old 03-14-2017, 08:54 PM   #2
Plumber
TheEplumber's Avatar
Re: main floor bathroom addition question
You can probably extend the line- assuming it's properly sized and graded.
Generally speaking, the clean out cannot be used as a drainage fitting. Cut it out and add it at the end of the new line. Or in the case of a stack, move it above or below the new branch
Tags
bathroom addition , plumbing code
Replace my main panel or main breaker? joe_oklahoma Electrical 16 12-15-2015 11:27 PM
Wire Sizes and Ground Question for Running 100A Subpanel from Main Panel Norcaltrd Electrical 14 03-22-2015 09:39 PM
question about grounding my old main fuse panel cmarcus3031 Electrical 13 11-19-2014 02:16 PM
main panel ground question ccbs1 Electrical 19 06-04-2014 09:45 PM
room addition question rampeyboy Building & Construction 5 02-07-2009 06:59 AM
