Main Drain Stack Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2016, 08:51 AM   #1
Rewards Points: 4
Good Morning! Please see the attached photo. My main drain stack has knocked due to thermal expansion for quite some time. Upon opening the wall I discovered that there were no bracing used, allowing the pipe to move about 1/4". I fixed this problem for the most part, however it still appears to be rubbing the 2x6 it runs through slightly. Unfortunately, there will be no wood left if I cut out the ~1" piece of the 2x6 remaining behind the pipe. The portion of the 2x6 in front of the pipe has already been mended.
I fully realize this is a mess. I didn't cut the 2x6 on its side, someone had did that long before me. My question is can I cut the wood around the main 3" pipe without causing myself a structural issue, or is that even possible to determine from the photo?
Thanks!
areed28 is offline   Reply With Quote
Old 05-25-2016, 12:46 PM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Main Drain Stack Question
It's ticking because the wood is tight around it.
SHEPLMBR is offline   Reply With Quote
Old 05-25-2016, 02:57 PM   #3
Rewards Points: 1,854
Cut it that 1 inch of wood that is left is not supporting anything.
New Guy Here. Main water line question... Freestyler Plumbing 8 11-26-2012 07:59 AM
Tie stack to main drain rtoni Plumbing 3 04-21-2011 06:49 AM
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 04:13 PM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 12:43 PM
Main vent stack moving / resizing / removing (///AG) SFX Group Plumbing 11 11-16-2010 06:47 AM
