Maax Shower Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2016, 01:44 AM   #1
Rewards Points: 6
Maax shower cartridge
Does any one know if a different brand will work? Shower can only be adjusted in a narrow temp range. A little too hot for my kids bath and a little to cold for my showers. Also if I replace the single temp adjusting to a basic hot and cold what is the name of the valve I would need?
Sully6541 is offline   Reply With Quote
Old 12-24-2016, 08:43 AM   #2
Rewards Points: 18
Re: Maax shower cartridge
I never heard of or saw a maax valve. However, most of the valves i have seen have an adjusting mechanism on them so that you can control the high and low temperatures. I havent adjusted one in years, but, from memory, two of the interior parts have gear like teeth that work together to create the high limit (hottest water) that would be allowed to come out of the faucet.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 12-24-2016, 08:45 AM   #3
hkstroud's Avatar
Rewards Points: 6,692
See web sites below.
Down load PDF, see page 13
http://www.maax.com/~/media/docs/......2011-03-29.pdf
Contact information for customer support
http://www.maax.com/en/contact-us
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 12-24-2016, 08:45 AM   #4
Rewards Points: 6
Sorry should have states hat I already adjusted it. Maax is one of those jetted tub/shower/body spray combos. Came with the house
Old 12-24-2016, 10:58 AM   #5
Rewards Points: 1,926
http://www.showerstore.com/support/s...tore-10282.pdf
About page 9 is setting temps.
Then you need to replace the cartridge things go bad including thermostatic valves.
Need help identifying off brand shower cartridge jmac875 Plumbing 3 03-03-2015 05:54 PM
Remove / repair shower cartridge impact18 Plumbing 4 11-18-2013 12:39 PM
How Do I Remove A Moen Shower Faucet Cartridge kgkings Plumbing 23 10-11-2011 06:08 AM
How to remove a Stanadyne shower faucet cartridge BillyRay Plumbing 2 11-16-2010 09:51 AM
shower faucet Cartridge leaks Dragontat2k Plumbing 2 05-21-2008 03:16 PM
