Lowering Kitchen Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2015, 03:28 PM   #1
Rewards Points: 68
Lowering kitchen drain?
Probably a typical rehab scenario: I am installing new cabs with a deeper undermount sink. the drain height is at 18", and I estimate the output of garbage disposal closer to 14-15".
The drain goes into the wall, and has it's reduced vent going up but bends sideways to meet up main stack. Looks like I would have to cut the main stack and install a lower Sanitary T using Fernco rubber unions.
The new cabinet is a 36 and the center is slight offset by about 6 inches but it seems like the P strap and garbage disposal output can be twisted to get it the reach the drain where it come out, so I am not looking to shift the drain left or right, just need to lower it 3-4"
This is a simple single sink drain/GD setup.
Anything wrong with my approach?
mycorrado is offline   Reply With Quote
Old 01-31-2015, 04:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 254
I think you're on the right track. But I'd use PVC repair couplings instead of ferncos- much sturdier and code compliant
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
BlackTiger (01-31-2015), Javiles (02-01-2015)
Old 01-31-2015, 05:30 PM   #3
Rewards Points: 582
yep your on the right track...agree with E don't use ferncos use repair cupplings they don't have the stop in them easy to work with ...
Old 01-31-2015, 06:01 PM   #4
Rewards Points: 68
Ah, ok Thanks!
The only ones I saw had a stop in the middle.
Old 01-31-2015, 06:11 PM   #5
Rewards Points: 582
Originally Posted by mycorrado View Post
Ah, ok Thanks!
thats ok too just harder to work with if you don't have any movement...but your good you can do it
Any tips for unclogging kitchen drain line with easy access? loftezy Plumbing 1 09-05-2013 02:20 PM
Separating Adjoining Kitchen Drain Lines MrBill_DIY Plumbing 5 01-22-2013 07:49 PM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Kitchen sink drain problem noodlygod Plumbing 10 08-16-2009 08:02 PM
Kitchen Sink Drain Problem Spark General DIY Discussions 9 06-14-2009 11:00 PM
