Low Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2017, 04:57 AM   #1
Rewards Points: 22
Low water pressure
Hi All,
We have low water pressure for our hot water. Runs very slow, would take a few minutes for hot water to reach the tap. This was caused because we changed the sink/tap and didn't know about the problem.
We now want to change the sink/tap again but we are not sure what will solve it. Would a 0.3 pressure tap solve this? I've seen 0.1's but these are very expensive. Any ideas
alexb123a is offline   Reply With Quote
Old 10-03-2017, 06:14 AM   #2
retired painter
Rewards Points: 1,968
Re: Low water pressure
Is this the only faucet with low pressure? A piece of trash may have fell into the line when the faucet was changed out restricting the flow.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
alexb123a (10-03-2017)
Old 10-03-2017, 06:17 AM   #3
Rewards Points: 22
Hi, Umm the other downstair hot tap seems fine and its just a normal tap. So you could be onto something, esp knowing the guy who changed it. Is there a best way to check it for someone with very little knowledge of these things? Or do I need a plumber?
Old 10-03-2017, 06:21 AM   #4
retired painter
I'd turn the shut off valves off under the sink, disconnect the supply line, set it in a bucket [have a towel handy] and then turn it on to see what the pressure is like. That may also flush out any trash.
alexb123a (10-04-2017)
Intermittent Low Water Pressure Mystery bmbouter Plumbing 5 10-27-2015 04:54 AM
Increased Water Pressure mike123333 Plumbing 18 04-11-2015 05:59 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
