Low HW Pressure On Second Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2015, 11:32 AM   #1
Rewards Points: 16
Low HW pressure on second floor
The hot water pressure is extremely low on my second floor even though the cold is just fine. The hot water tank is only about two years old. I have all copper pipes and the shut valves are opened all the way. There is only one bathroom on the second floor and I have the same problem with the sink and shower. The first floor works just fine.
This is a rental and this has apparently been going on for a while, but for whatever reason it is a problem now.
Any ideas why it would be so low?
This_old_dump is offline   Reply With Quote
Old 10-05-2015, 05:09 PM   #2
Rewards Points: 1,414
Pressure regulator(s), partially blocked pipes, water leak, crud in the aerators, it could be a number of things.
Tom738 is offline   Reply With Quote
Old 10-05-2015, 05:16 PM   #3
Rewards Points: 18,962
More likely they used 1/2 instead of 3/4 as a main supply line.
A 3/4" has twice the avaliable flow.
CompleteW&D (10-05-2015)
Tags
hot water , low pressure
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
Weird water pressure issue in house... tenants moving in today, any ideas? (w/pics) tireshark Plumbing 9 08-19-2014 03:54 PM
Another case of shaky floor djenka2 Flooring 2 11-15-2012 03:17 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
