Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2015, 07:30 PM   #1
Rewards Points: 2
low hot water pressure
The hot water pressure in my house (every faucet/shower) is low compared to the cold water pressure.This has been true since I bought the house about 1 year ago. I am not sure if this means all the hot water plumbing is clogged versus an issue with the hot water system?
If anyone has ideas please let me know.
bruins99 is offline   Reply With Quote
Old 07-07-2015, 07:41 PM   #2
Rewards Points: 582
check the in comming valve to heater, some heaters from lowes and h d had rubber dics on the hot side that restricted flow....just a thougth..
Old 07-07-2015, 07:45 PM   #3
Rewards Points: 18,960
What type plumbing?
There should have been a 3/4" from the main to the heater.
3/4" ran as a main run, then 1/2 to the shut off for the fixtures.
1/2" has 1/2 the flow of a 3/4" pipe.
Increased Water Pressure mike123333 Plumbing 18 04-11-2015 05:59 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
