Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2015, 08:31 PM   #16
Rewards Points: 446
I'm looking at your pictures and see copper fittings screwed directly into the steel tank fittings. Research dialectic unions and why they're used.
I'm betting that if you remove the copper fittings from the top of the tanks you are going to see a large buildup of "junk" right at the steel fitting going into the tank. This blockage will allow air from the first tank to flow through quickly as the first tank fills, but once the water starts to try and go through it the flow will slow greatly, as you're experiencing.
old_squid is offline   Reply With Quote
The Following 2 Users Say Thank You to old_squid For This Useful Post:
Ghostmaker (05-20-2015), tylernt (05-21-2015)
Old 05-21-2015, 11:42 AM   #17
P Marage's Avatar
Rewards Points: 87
So o managed to pull it apart and whada you know. Right where I thought the problem was, I say 95% blockage. We have a huge iron count in our water supply in my city (Calgary) so it only made sense that I was having buildup. This is what I found when I removed the pipe. My pipes are in shock and don't know what to do with all the added pressure. And not being a plumber I feel pretty proud of myself and my wife thinks I'm a god now :P Thanx for all the input from everyone. Low Hot Water Pressure-image-1622167891.jpg
P Marage is offline   Reply With Quote
The Following 4 Users Say Thank You to P Marage For This Useful Post:
jmon (05-21-2015), MTN REMODEL LLC (05-21-2015), TheEplumber (05-21-2015), tylernt (05-21-2015)
Increased Water Pressure mike123333 Plumbing 18 04-11-2015 05:59 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
