Loose Old (1960's?) Single Handle Shower Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2015, 02:29 AM   #1
Rewards Points: 20
loose old (1960's?) single handle shower handle
We have a basement shower with an original old single lever handle that is loose and not staying in place.... ie: it will slip down or over and the shower will go alternatively too hot or too cold. It also is tricky to get it to shut off completely... gotta jiggle it a bit into just the right spot. I would like to repair/replace it and am looking for advice as to how to proceed. I've replaced double handle set-ups before but never the single handle type. This looks to be a "ball" and not a cartridge type. I haven't taken off the back plate yet as the screws seem to be stuck and I didn't want to be hasty and break something.... we're still using the shower.
I tried tightening a screw on the bottom of the handle , but it wasn't going anywhere.
Any repair I can do? Or will I need to replace it? IF so, thoughts on the difficulty of finding something that would be able to use the current plumbing set-up? (I realize that to answer the last you may need me to get that back plate off... just let me know)
Thank you for any advice!
KerryOn is offline   Reply With Quote
Old 06-23-2015, 02:38 AM   #2
Rewards Points: 20
Posted pictures
Couldn't figure out how to post picture on this forum but fo have some posted on another forum at the plumbingforums[dot]com/forum/showthread.php?t=7632
Old 06-23-2015, 09:28 AM   #3
Special User
Rewards Points: 1,230
I don't know the answer to your question, except to say that a 60s valve probably isn't pressure-balanced (to protect against scalding when someone flushes a toilet or otherwise uses cold water elsewhere in the house) and should probably be replaced with a modern valve at this point anyway.
Oh, and here's a clicky link to the pictures: http://www.plumbingforums.com/forum/...ead.php?t=7632
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Tags
mixer , shower handle , single handle , single-lever
squeeking shower faucet handle? what does that mean? daluu Plumbing 0 05-07-2013 02:14 PM
replacing old Moentrol single handle shower rskarma Plumbing 2 06-30-2012 05:51 PM
Shower Door Transom is loose 2031pratt Plumbing 0 12-28-2010 11:26 AM
Kohler single handle shower randy717r Plumbing 1 03-29-2008 11:35 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 08:08 AM
