Loose Kitchen Faucet - Single Spout Moen - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2015, 11:40 AM   #1
Rewards Points: 2
I recently moved into a new (for us) home. The kitchen sink has a single handle, pull out spout Moen faucet installed. I am not 100% sure of the model number but after a review of the Moen site it appears to be in the 7560 family of faucets.
The faucet itself is loose to the point that when we attempt to aim it from one sink to the other the baseplate spins and it wobbles slightly. I've gotten under the sink to tighten the nut that holds the faucet in place but in order to get it tightened to the point the faucet baseplate doesn't spin I have to tighten it to the point where the faucet itself will not rotate between sinks. The more I tighten it at the bottom the more it seems to bind the faucet from swivelling.
Is there a step I'm missing or is there another problem that needs to be addressed?
Klammern is offline   Reply With Quote
Old 07-01-2015, 02:58 PM   #2
Rewards Points: 1,932
Probably not installed correctly.
Old 07-01-2015, 05:50 PM   #3
Rewards Points: 582
sounds like it is missing a gasket ...I would take it off and reinstall it ...see if you can get an installation guide online... pdf adobe file on faucet open it ..
Tags
loose , moen , single spout
Moen Kitchen Faucet Leak and Limp Handle DenfromDanbury Plumbing 9 10-27-2018 01:51 PM
Kitchen Faucet Sprayer Does Not Work. Already Replaced Diverter. latenight Plumbing 13 08-12-2013 04:27 PM
Loose kitchen faucet veritas Plumbing 13 02-01-2013 08:54 PM
Moen kitchen sink issues. (Pictures included) Largest Plumbing 2 12-02-2011 04:34 PM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 09:36 AM
