Loose Compression Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2015, 04:32 PM   #61
Solidify's Avatar
Rewards Points: 834
I just can't understand why so many people cut corners, installing pipes like that in a door casing...
Solidify is offline   Reply With Quote
Old 09-04-2015, 12:12 PM   #62
Solidify's Avatar
Rewards Points: 834
I have a spare GFCI outlet from 3-set that I bought earlier this year. Would this lower outlet that the pipe heater plugs into warrant me replacing it with a GFCI outlet, since it's in a space with exposed plumbing, or would it just be good practice? (Mind you, the entire panel is at risk too lol)
The heater doesn't say it needs a GFCI though, I'm just thinking precaution:
Old 09-04-2015, 04:31 PM   #63
PoleCat's Avatar
Rewards Points: 1,658
I would not bother with the GFCI.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-04-2015, 04:51 PM   #64
Solidify's Avatar
Rewards Points: 834
Any particular reason?
Old 09-05-2015, 10:54 AM   #65
PoleCat's Avatar
By definition this is not a wet location.
Old 09-05-2015, 01:08 PM   #66
Solidify's Avatar
Rewards Points: 834
And by definition a garage is (a wet space)?:
I don't understand.
Old 09-06-2015, 06:20 PM   #67
PoleCat's Avatar
Your house and wiring appear to predate all the codes in the above table. Heat tape itself is submersible. If you want to install a GFCI go for it. By law you are not required to update your home's preexisting wiring to the latest code.
Old 09-06-2015, 07:01 PM   #68
Solidify's Avatar
Rewards Points: 834
Ok good point. I'll leave it as is.
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 13 07-03-2017 04:29 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 04:34 PM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
