Looking At Plumbing Dehumidifier - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2015, 03:38 PM   #1
Rewards Points: 415
Looking at plumbing dehumidifier
I finished up my finish basement, though I am getting tired of emptying out the tank. I have a slop sink on the same outside wall as the dehumidifier. I would like to add a a "T" fitting to the sewer side of the trap, reduce the diameter of the pipe going to the dehumidifier to 1.5", add an inline trap, then connect the hose of the dehumidifier to the drain pipe. I would like to make sure I do this in a proper manner and I am pretty sure the outlet for the dehumidifier has to be GFCI. I know I need to have 1/4" for every foot. I am curious do I also need some type of vent and am I doing anything wrong in my theory/plan? The sink is sits next to a large diameter PVC pipe, 6" I think.
Solaritu is offline   Reply With Quote
Old 08-20-2015, 03:49 PM   #2
Property Mgt/Maint
Rewards Points: 8,202
Any chance of installing the DH above the slope sink right next to it?
If so you can just drop the DH hose over the edge of the sink. No plumbing involved.
Just make sure it can't roll of if its on wheels.
Old washer hoses work well for short drain lines
[political signature removed]
Yodaman is offline   Reply With Quote
Old 08-20-2015, 03:59 PM   #3
Rewards Points: 278
You could get a condensate pump and some tubing. Have the dehumidifier drain into the pump and run the tubing to the sink.
Dan
djlandkpl is offline   Reply With Quote
Old 08-20-2015, 04:08 PM   #4
Rewards Points: 5,348
The problem will be with the trap when there's no water in it. Sewer gas will get into the house unless you cap the trap when the unit is not in use(in the Winter months.)
The condensate pump is what I use on the older unit.
Ron
B. Franklin 1759
Old 08-20-2015, 04:13 PM   #5
Rewards Points: 1,928
No floor drain in the basement? Or storm sump?
Old 08-20-2015, 04:51 PM   #6
Rewards Points: 415
Funny thing. I have a condensation pump for my ac and humidifier. I have another dehumidifier on a shelf draining into the sink for the unfinished side. I might go the condensation pump route, will need to install two outlets if I do. I was hoping for a more passive method
Old 08-20-2015, 07:56 PM   #7
Rewards Points: 127
I sold my parents condo a while back. The builder had drained the condensate pump for the furnace directly into a sewer line. No no. We had to a trap into a essentially a small standpipe larger than the drain house from the pump to create a sysphon break. Keep it simple. A condensate pump with a hose to your slop sink. Done and simple.
jimn01 is offline   Reply With Quote
Old 08-21-2015, 07:53 AM   #8
Rewards Points: 415
I think you guys have help me make up my mind. My main worry is when a pump fails and if I don't notice it, then I will get water in the basement
The condensation pump I installed for the AC and the replaced a pvc pipe that drained into the floating slab. I am wondering If I should put it on some type of buck that has a drain hole to the floating slab, that way if there is a problem it will drain into the floating slab and not all over the basement floor.
Old 08-21-2015, 08:41 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
Many condensate pumps have alarm contacts, wire a relay to cut off the AC to the dehumidifier if the pump fails.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 08-21-2015, 08:51 AM   #10
To compensate for a dead pump, put an alarm device next to the pump. I'm sure you can now find ones that send a message to your phone. You can also just go for the local alarm that rings.
Ron
B. Franklin 1759
Heatpump as Dehumidifier RCrosby257 HVAC 5 11-15-2014 06:35 AM
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 11:50 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
