Looking For A Hot Water Heater Solution For New House... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2016, 04:48 AM   #1
Rewards Points: 4
Looking for a hot water heater solution for new house...
We are finishing up a new home build and are looking for a solution for our needs.
We have been planning on a tankless water heater since conception. My contractor was ordering and somehow, the energy calcs for the heater was not included by our architect!
Our home does not have any gas, so Electric is the way we have to go. I may be able to add solar supplement down the road, but currently is not planned.
We have 320 amp is 400 amp @ 80% rated main panel feeding into 2 sub panels of 200 amp each. One for the house and one for the connected wood shop.
Hot water demands are for bathing:
3 showers (morning use mostly) two may typically be used at the same time, the third is in the shop and planned usage is rarely
1 85 gal tub used nightly
laundry about 8 loads a week.
Our "home" circuit panel is apparently fully used, so it seems we will need to be using power from the shop sub panel.
I don't want breakers to be popped every time I run my lathe, shaper (2-3hp motors), saw(5hp motor) etc.
We also dont want to run out of hot water while taking shower or filling the tub. Tub and showers will rarely be used at the same time, sometime 1 shower maybe ran when filling tub.
With the available power, and our desire for continuous (or appearing to be) hot water, what system(s) would be best? I have about 3k if needed for the heater system, so if need be combining 2 heaters, that would be OK. MFG & models would really be helpful!
As a side note, we are TRYING to meet LEED for Homes, but comfort may dictate otherwise.
We do have 11.4 kW Solar panels, but it is my understanding that these should not be used in the demand calcs.
Thanks! Bruce
mctabish is offline   Reply With Quote
Old 05-15-2016, 08:07 AM   #2
Rewards Points: 2,114
Re: Looking for a hot water heater solution for new house...
Hi Bruce, I'm not a good one for recommending your heater but wanted to comment. You say "TRYING to meet LEED for Homes" yet your description for hot water needs and use seem to be miles away from that goal.
Leed implies conservation, so what are you and yours doing personally to conserve.
I apologize for my perspective, I'm a retired energy auditor, as I have always looked for ways to use less. Adjusting to the new world where an acre of solar panels can support a lavish "home energy" style is proving difficult for me.
Bud
Bud9051 is offline   Reply With Quote
Old 05-15-2016, 08:09 AM   #3
Rewards Points: 18,784
Why not consider LP?
They could even install a underground tank for a better look.
Faster recovery, far cheaper to run then electric.
Old 05-15-2016, 09:06 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Hybrid electric 75 gallon water heater?
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Ghostmaker (05-15-2016)
Old 05-15-2016, 12:42 PM   #5
Rewards Points: 4
Bud9051, you are correct!
Water is being captured in several ways. All rain water is captured to 20k tanks for storage for irrigation (and fire control), gray water is also captured and used daily for irrigation. Non permeable surfaces are also captured. We have 2.5 acre and have left most of the property native. We will have fruit trees/plants and veggies.
I need the tub due to a back injury.
We have spray foam insulation. Heating is provided by a heat pump and radiant heat. We are using solar with plans to add more.
We do want to live comfortably, but where we take, we try to replenish. We are trying to make what we DO use, go as far as possible.
A/C is seer 18.5, Merv 15
Title 24 calcs are 33.7 above Title 24, not including input from solar (as is standard). This was including a Stiebel Eltron Tempra 29 Plus 28.8 kW , but did not account for the circuit load on the breakers.
The shop is my livelihood.
Our efforts HAVE been there, and HOPEFULLY we will meet the goal. We have been paying LOTS for all of the adjustments to meet the goals and we have hired a LEED certifier and have been working with him throughout the project, so we are (were??) all on goal to at least be certified. I WAS shooting for Platinum, but we cannot make that, so we will have to settle for between certified and gold.
Last edited by mctabish; 05-15-2016 at 01:04 PM. Reason: wording and adding details
Old 05-15-2016, 02:21 PM   #6
Thanks Bruce,
I was feeling a bit guilty about poking you in the ribs, but after reading your reply I'm glad I did. Really nice project and if you can, fill us in when it is done.
CA I assume?
Bud
New hot water heater issue with water quality and potential resolutions biggerdaddynj Plumbing 11 04-13-2016 10:17 AM
A Water Heater, an Outlet, a Cable and a Breaker Koldhammer Electrical 1 02-19-2015 04:43 PM
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
